Low speed wobble ,,help
Old Mar 30, 2010 | 01:46 PM
gaser's Avatar
gaser
Unhappy Low speed wobble ,,help
I have a 2007 r/g the bike has never had a front wobble till this year . Over the winter i pulled the motor an did a 110 se upgraade . Reistalled motor a took it out for a ride . This is when the low speed wobble started . It only dose it when you are slowing down from 40 mph . High speed is fine , do you guy's think the motor is out of alignment .,,,need help ps i did not lossen any of the himes
Old Mar 30, 2010 | 01:52 PM
harley1958's Avatar
harley1958
Check your neck berrings --- they could need to be tighten up.
Old Mar 30, 2010 | 02:09 PM
gaser's Avatar
gaser
I did check the streering head an even set it a little tighter ,, no change
Old Mar 30, 2010 | 02:30 PM
Road Ranger's Avatar
Road Ranger
Did you check tire psi...I 've had that happen before.
Old Mar 30, 2010 | 03:10 PM
SF_Moreno's Avatar
SF_Moreno
6th Gear
Default Low speed wobble
that is probably the correct fix. I've had people come in and say that they have a wobble when they pull their bikes out after winter. They do everything else but forget to check the tire air pressure. They have come in with as low as 6-7 psi. They were lucky to make it in I say. While you are at it check to make sure you haven't got any bad cupping due to under inflation. Hope that helps and Get Ridin'.
Old Mar 30, 2010 | 03:17 PM
gaser's Avatar
gaser
Tire psi good tire have about 3000 miles on them
Old Mar 30, 2010 | 04:51 PM
BC Glide's Avatar
BC Glide
I would check the things you changed over the winter; alignment would be the place to start.
Old Mar 30, 2010 | 09:21 PM
LVdennis's Avatar
LVdennis
The bags have to weigh even. The tire alignment also can cause this. I have the same problem from time to time. Usually its an uneven weight in the bags, or the tire alignment. This being said after you checked the above mentioned stuff. Good Luck
jstorrusten
Oct 12, 2011 02:03 PM
blink1968
Jun 12, 2011 06:21 PM
Badbagger
Mar 19, 2009 09:22 PM
lowflyby
EVO
Aug 22, 2008 04:35 PM
Harley kevbro
Exhaust System Topics
Dec 26, 2007 08:36 PM
