RPM's @ 70 MPH?
Old Aug 22, 2008 | 09:23 AM
lowflyby's Avatar
lowflyby
Default RPM's @ 70 MPH?
I bought the 1998 Softail used and it's hop up with 84hp and 80 lb/tq and I am running 2600 rpms @ 70 mph. I was thinking about putting a 6 speed in over the winter but my buddy has an 02 Softail and he runs 3000rpms.
So what does the stock bike run @ 70 mph so I can check to see if someone has changed the pulleys or sprockets.
I don't want to put a 6 speed and find out I'll be bogging on the highway.
Old Aug 22, 2008 | 09:36 AM
Dr.Hess's Avatar
Dr.Hess
That seems to be pretty low for 70 to me. My bike is around 3K or so at 70. I bet someone has already changed your gearing somewhere. I'd think you'd be bogging a bit with even higher gearing.
I don't understand why people want 6 speeds anyway. The HD motor makes plenty of torque in a big broad band. 5 speeds is more than enough to match motor to wheel. It's not like my 4AGE 20 valve with gobs of HP but nothing under about 5K RPM, then hang on. That motor needs lots of gears, and a 6 speed could help it.
Old Aug 22, 2008 | 09:54 AM
lowflyby's Avatar
lowflyby
Just looking to reduce the vibrations a little. I have no reference at what it is stock so adding a 6 speed would bring me down to about 2200pms @ 70mph and I thought that might be too low, or too good to be true, since there would be no vibration at all around 2100 rpms.
Old Aug 22, 2008 | 10:32 AM
Teflon Tom's Avatar
Teflon Tom
Default Go with the Baker DD6
I'd go with the Baker DD6 check out the Baker site. You don't need and OD 6 speed you have to be topping out all the time and speeding tickets are a bitch.
Old Aug 22, 2008 | 10:35 AM
paco's Avatar
paco
my 90 Flht runs 3000 - 3100 @ 70 mph in 5 th. 6 gear it runs 2600-2700 @ 70 mph.
later......................
Old Aug 22, 2008 | 02:39 PM
t150vej's Avatar
t150vej
'87 FLT stock 5 speed, does about 2600 @ 55 and 3100 @ 70
Here is a link to the BAker page that will help clue you in...
http://www.bakerdrivetrain.com/gearratios/index.htm
Old Aug 22, 2008 | 03:52 PM
mjunk1's Avatar
mjunk1
90 FLHTCU runs about 3100 @ 70mph.
Old Aug 22, 2008 | 04:35 PM
Doc 1's Avatar
Doc 1
You must have the 68 tooth rear sprocket on your bike....most all the rear sprockets are 70 tooth except for the international rear sprocket the MoCo had for a short period of time.
CaptainHook
Apr 7, 2015 05:05 PM
JohnnyRebKY
Jun 2, 2014 11:34 AM
DeluxeHog05
May 19, 2010 11:27 AM
6speed
May 3, 2009 07:59 PM
lightu
Aug 2, 2006 12:57 PM
