2005 ultra forks
Old Mar 31, 2010 | 07:24 AM
yota's Avatar
yota
Default 2005 ultra forks
I just got my parts in and am planning to change old HD style front fork set up to the Progressive Monotube set up. Reading in the manual is not clear..Does the entire fairing need to come off or just the outer piece and the cover under the ignition switch. Manual kinda questionable.
Old Apr 1, 2010 | 07:33 AM
yota's Avatar
yota
Default Am I the first
I am sure someone has had this all apart fir 1 reason on another..So BUMP..
Old Apr 1, 2010 | 07:51 AM
'05Train's Avatar
'05Train
You only need to remove the ignition switch and console, the outer fairing can technically stay put.
Old Apr 1, 2010 | 12:37 PM
yota's Avatar
yota
Default Outer fairing stays in place.
I think you mean inside stays in place..I think anyways. As the pinch bolts are behind that part..Correct..???..Has anyone done this task and if so any tricks to help things along.
TriGeezer
Sep 27, 2018 11:12 AM
shovelheadred
21
Feb 4, 2014 07:29 AM
rstlnfan1
May 29, 2012 01:51 PM
CREEPSHOW
Apr 13, 2008 10:07 AM
mllkn6
Apr 2, 2008 11:02 AM
