I need to replace the lower inner fairing on my ‘12 TriGlide. Officially called the ‘Inner Fairing Cap”. The procedure requires removing the ignition
/fork lock. The procedure in the service manual indicates the use of specialty tools: Ignition Switch Connector Remover and an Ignition Switch Alignment Tool.
Has anyone done this procedure, and did you need the tools?
Thanks!
