Mainshaft sprocket removal socket
Old Mar 31, 2010 | 03:51 PM
makstv5's Avatar
makstv5
Default Mainshaft sprocket removal socket
Would someone know how deep of 2 1/4'' socket i need to remove the sprocket/pulley nut on 2010? I want to cut one of my shallow sockets and lengthen it with a section of pipe to go over the mainshaft. I'd rather use up some of the sockets i already have than buy the HD one.
Old Mar 31, 2010 | 07:16 PM
makstv5's Avatar
makstv5
Default Rear drive belt replacement
There must be someone that changed their own rear belt and can give me a idea on how deep to make this socket?
Old Mar 31, 2010 | 07:24 PM
dawg's Avatar
dawg
See attached. Looks to be about 3" welded on
Old Mar 31, 2010 | 10:57 PM
tenn.vol.'s Avatar
tenn.vol.
My son bught a deepwell socket from NORTHERN, maybe $22.00 and added
about like in DAWG pic. I am thinking teh socket was 6 sided. A cheep fix with
a cheap socket for sure.....Tenn.Vol.
Old Mar 31, 2010 | 11:53 PM
BLKBAGGER's Avatar
BLKBAGGER
While you are at it face the socket on a sanding wheel. You will get a lot more bite out of it.
Old Apr 1, 2010 | 04:36 AM
makstv5's Avatar
makstv5
Default Face the socket?
Do you mean get rid of the leading edge where the radius is on the bottom of the socket? This is to get more of the flats to contact the nut on the mainshaft?
Old Apr 1, 2010 | 04:47 AM
makstv5's Avatar
makstv5
Default Looks like what i started
I have the same arrangement but i cut 8'' of pipe to be on the safe side. I also didn't make that plastic mainshaft thread protector. I think if your careful you don't need that piece. Now i have to come up with a tool that allows me to lock the belt pulley without marring it at all. Thank you very much for the pic Dawg
Old Apr 1, 2010 | 07:52 AM
BLKBAGGER's Avatar
BLKBAGGER
Yes grind back the radius about 1/8"
Old Apr 1, 2010 | 12:34 PM
makstv5's Avatar
makstv5
Default Thank you too
I guess the nut is thin? Any easy locking tool for the belt pulley you know off?
Old Apr 1, 2010 | 12:56 PM
mfglideman's Avatar
mfglideman
why are you messing with the belt already?
