New 95 build has tick noise
Old Apr 2, 2010 | 08:46 AM
customsoftail200's Avatar
customsoftail200
Yea, it gets more noticeable as it warms up..
Old Apr 2, 2010 | 09:03 AM
flhtupser's Avatar
flhtupser
I put a lot of thought and readj. my pushrods 2 or three times to no avail after the install. Read where some come out quiet and some noisy. The lash on my drive gear was within spec but I bet was on the loose end of the spectrum. He could have maybe used the oversize gear and it would run quiet. Or as Dawg said the rocker boxes could need adj. and as the motor grows with heat the tolerances change and the pushrods make slight contact making the noise. Mine runs great and I've heard others that sound just like it so I no longer worry. Those are some options you may explore or like many others get used to it and ride the hell out of it. My 2 cents.
Old Apr 2, 2010 | 09:21 AM
andyp's Avatar
andyp
A few yrs ago I did a 95 in build with andrews 26 cams and mild headwork.And with the cams you will hear more.I also had a tick,tried adjusting lifters a few times to no avail.Anyways after awhile,I had a lifter bleeding down,noisy on startup.Changed lifter and sounds great.By the way,all lifters were changed at build,so I had a defective new lifter.
panhead12004
Exhaust System Topics
Jun 8, 2012 02:09 AM
Hog Yild
Jan 14, 2012 07:13 PM
TedMan
40
Apr 16, 2010 01:12 PM
tree88
13
Aug 7, 2008 01:16 PM
bluesguitar
Nov 13, 2007 09:04 PM
