Stereo Handle bar controls Not Working????
Old Apr 2, 2010 | 06:28 AM
spence222's Avatar
spence222
Default Stereo Handle bar controls Not Working????
Have an 06 Ultra with the Biketronics Stereo 400w amp...have had zero issues with it for the past 2 years. I fired the bike up 2 weeks ago stereo working but unable to adjust volume or change channels by way of handlebar controls, I pulled the fairing checked all connections and grounds...all good, pulled the fuse box and checked all the fuses...all good...but here's the the clincher...after checking fuses I had control of the stereo at the bar controls with the bike running...buttoned everything up and hit the road...NO HANDLEBAR CONTROLS WTF?? Anyone have a clue to this problem??
Old Apr 2, 2010 | 08:55 AM
spence222's Avatar
spence222
Cmon.....no one has a clue?? lol Help a brother out!
Old Apr 2, 2010 | 09:24 AM
D2R's Avatar
D2R
Did you unplug the retro-radio con. and reseat it.Thinking it might just be a high resistant pin in the plug coupler.If neither controls work on your handle bars thats where I'd look.If only one of the controls doesn't work it might be that button.I'd call Biketronics if that doesn't help.They'd probably have an idea or 2.Intermittent elec. problems are a pain.
Old Apr 2, 2010 | 09:36 AM
D2R's Avatar
D2R
Sorry Spence should have read your thread better.Is it the HK radio with the amp or aftermarket with the retro radio kit? Id still think it's in the plug conn. if neither control works.
Old Apr 2, 2010 | 09:47 AM
Geoff of NV's Avatar
Geoff of NV
Spence,
Same thing happened to me a couple of years ago. Pull the fuse to reset the Biketronics adapter and good to go for a while and then it'd happen again. Asked Biketronics to replace the adapter and no trouble since. Don't forget that their stuff is guaranteed forever.
Old Apr 2, 2010 | 11:32 AM
spence222's Avatar
spence222
Originally Posted by Geoff of WA
Spence,
Thanks Geoff....What fuse are you referring to? the one at the stereo or down in the fuse box?
Old Apr 2, 2010 | 11:33 AM
spence222's Avatar
spence222
Its the Sony from Biketronics....I'll check the plug conn. again. Thanks for the reply...appreciate it!
Old Apr 2, 2010 | 11:47 AM
D2R's Avatar
D2R
Hope you find the bug.I installed the Retro-radio this winter so would be interestd to know what you found.The people at Biketronics are great talk to if you run into a brickwall.Like Geoff say's their stuff is warrantied for life if it is their gear.
Old Apr 2, 2010 | 02:23 PM
spence222's Avatar
spence222
Called Mike at Biketronics....he asked if I changed battery or disconnected the battery this winter....I did, was advised to disconnect 1 lead to the battery and let it set for 10 minutes....Problem resolved...by disconnecting the battery the system somehow resets itself...hope this can help someone in the future....thanks for the replies guys!
Old Apr 9, 2010 | 11:07 AM
nikosflht's Avatar
nikosflht
hello spence22,thanks god you solve the problem!!!!i just order the bt module 1005 from biketronics and i was wondering what i will do if i wiil have this problem because i am so far away from your country.now i know were i will have to take a look.THANKS!!!!
