Rev limiter
Old Apr 5, 2010 | 04:47 PM
hydrolock43's Avatar
hydrolock43
Default Rev limiter
When i hold my bike open and it hits a little over 5000 it feels like the ignition is skipping. is that the rev limiter? Would enabling rev extend to 6200 make this less noticable when i go to shift a little over 5000. I never noticed a rev limiter so pronounced on other bikes i own. This is on a 2010 efi
Old Apr 5, 2010 | 05:03 PM
oldbagr's Avatar
oldbagr
Not sure if it is the rev limiter on your scoot that is causing this problem; however, I have a Stage 1 on mine which extended the limit to 6200 and when I hit the limit it basically dumps all the compression until I back off the throttle.
Old Apr 5, 2010 | 08:20 PM
hydrolock43
Default dumps the compression
What does that feel like?
Old Apr 5, 2010 | 08:29 PM
nvsteve's Avatar
nvsteve
Like you turned the ignition off under full throttle.
Old Apr 6, 2010 | 01:24 PM
oldbagr's Avatar
oldbagr
It is weird but the engine pulls hard right up to redline and then it is like all the compression is dumped. The engine wont respond until you throttle back and let the rpm's drop or quickly upshift into the next gear. The engine responds again as soon as the rpm's drop below the limit. It is something to be mindful of if you are accelerating at full throttle through the gears; you need to watch the tach if you have done a build with cams because most after-market cams will get you to redline much quicker than your stock setup... just make sure you upshift before hitting the limit or you are going to loose power, etc.
Old Apr 8, 2010 | 12:07 PM
grumpy old biker's Avatar
grumpy old biker
I do not understand why anyone would rev a Harley this high. Look at most dyno charts and you'll see the torque drops out some where between 3000 and 4000 rpm, depending on setup. Shortly after it starts to drop you are not really gaining anything extra. Anyone who knows where their max torque is and shifts and stays in that top band will out run anyone reving the crap out of their bike. Just 'cause you can doesn't mean you should.
Old Apr 8, 2010 | 05:05 PM
ryanl's Avatar
ryanl
Mine is set to 6200rpm and I hit it from time to time. Sometimes I just keep my foot pulled up against the shifter and as soon as the limiter hits it pops into the next gear. I guess if I had a bike that stopped producing power at 4000rpm perhaps i would shift sooner. Thought i would add that I can easily outrun anyone that only makes torque for that narrow of a range no matter when they shift
Old Apr 9, 2010 | 10:37 AM
grumpy old biker
Ok! Show me your dyno chart. When your torque starts to drop away there is no reason to continue to rev the hell out of the bike. A HD down load or a PC rev extend etc., raising the rev limiter is not the point, and means nothing. If your torque is falling away, whether it be at 3, 4, 5000 rpm, any rpm rise after that is a waste of time and flogging your engine for little or no gain. Just because all your horsepower comes in at 6000 rpm, again means nothing. Torque is want gets you up to speed, horsepower is what maintains that speed. Building an engine for torque will guarantee you get horsepower, building an engine for horsepower doesn't guarantee torque. I'll take torque over horsepower any day of the week, that's the whole point of a Harley. Thought I would add - read my original post. I did not state that the bike would only make torque between 3000 and 4000 rpm, only that it would start to drop somewhere in that area depending on setup.
Old Apr 9, 2010 | 11:14 AM
grumpy old biker
I'll also add a little more gas to the fire. Everyone who is slapping 95" or 103" barrels on their bikes with out flowing the heads are wasting their money. The heads on 88" and 96" engines are just barely meeting the demands on a stock engine. These kits are the biggest over sale on the market today.
Old Apr 9, 2010 | 05:43 PM
nvsteve's Avatar
nvsteve
Could be wrong but I think you have it reversed. I believe you shouldn't rev past peak horsepower. I'm just speaking of peak performance as in racing. I would agree if you're speaking of cruising thru mountain roads.
