Powder Coat Fix?
Old Apr 6, 2010 | 10:22 PM
booze hound's Avatar
booze hound
Angry Powder Coat Fix?
Hello all-
don't post much here but search the site often for useful info, of which there is plenty. Thanks to all that keep me learning!
Just noticied that below the steering neck on the down tube of my frame that the powder coating is starting to flake off. Small now, but will probably just get worse over time.
Wondering if anyone knows of any trick to prevent this from becoming a full blown problem. It is really not very noticible now, and if I can stop it from becoming worse I can certainly live with it. If it continues I am gonna be severly bummed.
I was thinking maybe some kind of paint, clear coat, light coating of clear silicone?
Thanks for any and all ideas.
Old Apr 7, 2010 | 08:45 AM
GMONEY220's Avatar
GMONEY220
I think HD is painting the frames and not pcoating them,Kuryakyn makes some covers for the neck and tubes if it becomes an eye sore
if u have the time a quick coat of gloss black and rust-o-leum clear coat should fix you up.Get a (2)fine grit sanding block (the ones that actually look like a sponge,start with the rougher of the two then finish with the other.Try and get the area as smooth as possible,clean good and paint it
Old Apr 11, 2010 | 07:27 PM
booze hound
Thanks for the suggestion and advice. Will give it a close look over the next day or so and see if I can get it resolved.
Drtumolo
Powdercoat & Paint
Apr 7, 2018 01:39 PM
davidstipek
Powdercoat & Paint
Mar 17, 2018 08:38 AM
Ozark Joe
Jan 3, 2016 11:29 PM
roofer
Dec 17, 2009 04:14 PM
rounder
Nov 10, 2008 04:08 PM
