Misinformed on 103 Build and Cams....
Anyway, at least you're getting the correct part this time around--hopefully. It's just that you are the third guy on this forum alone who's purchased 255's and reported being sent the wrong cams. In one other case the seller was very apologetic and bent over backwards to right the wrong, but you still have to wonder.
1) the map Jamie sent me is exactly what I asked for, a stage 1 103. Turns out what I asked for isn't what I needed as I have the cam and accompanying ECM download.
2) I have made no changes to the timing area of the map because until it got hot yesterday, I hadn't really had much trouble.
3) I was running up to 14.6 AFR's in the cruise range. I went in and dropped them to 14.4
4) Once heat becomes an issue the ECM may be in fact retarding my timing even more, leading to pinging and reduced performance.
I think the CAT headpipe has a lot to do with it as well due to the heat build-up. Once I get the new map and headpipe I think all will be well
Again, not slagging anyone or their products, but generic maps are for generic bikes. They don't take into account your riding environment, your gas quality, or any quirks of your bike (is the compression in both of your cylinders the same?). The TTS allows you to data log and see exactly what the bike is doing when you ride it. If you're getting detonation, it shows you where. And it also allows you to keep the factory knock sensor so you don't grenade your motor.
To the OP, I know it's gotten to be in style to blame the catalyst for all the bike's ills, but I think you'll be very happy with the way it runs once you get the proper map in it.
Sorry, but the CAT in the headpipe is probably the single biggest problem I have right now. It leads to heat buildup in the motor very quickly and once the cylinder head temps reach a certain point and the ECM retards timing it wouldn't matter what tuning device I was using. Performance goes to the crapper at that point. Remember, all of my problems occur when my oil temps are over 230 degrees. I would like to know what my head temps were at that point, but I can tell you I was in the throttle pretty hard. With the restrictive CAT headpipe where is all that heat going? Building up in the heads I would guess. Once I get rid of the cat and see if I require any timing changes I'll report back my findings.
I still think that there's something wrong somewhere that's causing you to lose power, and from my experience with a bike with a converter, I don't think that's it.
The PCV software has the capability to display cylinder head temps. The problem is, by the time you pull over, start-up the laptop, open the software, and connect to the PCV....well, head temps have either come way down (shut down motor), or gone way up (idling).
For troubleshooting purposes an infrared thermometer would probably be more effective. Of course I would still pull over to use it, cause I'm no daredevil. Worth a shot though to aid in diagnosis...
