Misinformed on 103 Build and Cams....
Get it tuned once your new pipe is on and I bet you see a big drop in oil temps.
Zach
I have zero experience with data logging and have never adjusted timing. This is an area I previously chose to avoid. I know ICLICK has done some timing work with his scoot without going on the dyno... I do think this would be a useful tool, even if not completely necessary to get a tune that is void of pinging and detonation.
I agree with the loss of power. With the 255 cam, 103, CAT headpipe, and Dyno-tuned Jackpots I had 97 TQ and 80 HP. TQ is almost where it should be with this setup. HP is lacking. To me, the headpipe and heat soaking would explain this. Jamie has done extensive testing with the CAT and non-CAT stock headpipes and in development of his new 2-1-2 pipe. I would think he has more info on this than any of us. Maybe he will chime in...
Zach
Because the ECM already has the timing adjustment accounted for, wouldn't it stand to reason that there would be no timing adjustments necessary?
I have "0's" in every cell of my timing map right now. Should I try retarding the timing a bit across the board (2-4%)and see what happens?
I'm not at all familiar with the Power Commander, but having all your timing tables at zero indicates to me a dyno tune is needed. The Auto Tune does nothing for your timing. Get it to a competent tuner once your pipe is installed. You will be amazed at the difference.
If you haven't guessed, I'm not a big fan of the Auto Tune systems. But that's just me.
Zach
I'm going to borrow a new LCD-200 from a friend for a while, long enough to do some data-logging. I'll probably do a write-up on it, but I'll be damned if I know where I'm going to mount the thing! There's just no place for it to go on this bike without blocking something. I may just velcro it to the bottom of the dash near the seat, but if I can keep it a while longer I may try to mount it on the handlebars somewhere with a Ram mount or Techmount.
Another idea is to have someone ride with you and hold a laptop computer connected to the PCV. When it detonates have the rider check the TP and RPM's, and that'll help you isolate where the detonation is occurring. Then pull over, knock the advance down 1% at a time in the appropriate places until it is no longer heard. For example, if you hear it at 2500 @ 20% TP I would retard 1° from 2000-3000 @ 15-20%, maybe also at 40%.
Keep in mind that when you adjust your AFR's or timing in the TTS software you are also sending altered data to the injectors, and that is the general idea of all tuners.
Since I'm running very rich in the cruise range of the base map and very lean AT target AFR's, I can take advantage of the rich base map to cool the bike when needed yet run the leaner closed-loop mode (AT) most of the time for better mileage. This can be toggled with the map switch at any time on the fly. Because of this strategy I'm seeing double-digit negatives, up to -31%, in some areas of the cruise range, but this is expected. AT has absolutely no trouble adjusting to these wide differences in tuning, and you don't need to "accept trims" periodically to give AT less work to do.
While on this subject a few more things should be noted. PCV-AT will allow closed-loop operation in the entire RPM/TP range, not just up to ~50% TP. TTS uses the stock narrow-band sensors which limit you further, allowing adjustment only between 14.2 and 15.0:1 AFR. The PCV-AT with its wide-band sensors allows ~11-16:1, far leaner and richer than anyone would likely use. The lower limit of 14.2 would be more than enough for me, but many would want a richer configuration at part-throttle to better control heat.
Thus, you can attach a PCV-AT with any map, even one completely zeroed, and in a short riding cycle you'll have a map that is correct throughout the RPM/TP range and without a dyno tune. It will continue to tune by trimming the base map at the rate of 50x/sec. at all times while you ride. To tune TTS above 50% TP you must perform a dyno-tune or install an accurate map that has already been created on another bike. No matter what is said about V-Tune, you have no feedback above 50% TP and you simply can't do it accurately. That's not to denigrate TTS but I only want to point out that both tuners have their minor strengths and weaknesses in features provided, but both are very competent tuning solutions.
Frankly, I don't think you quite understand how a PCV works, and the fact is that like TTS, SEST, T'Max etc. it is a very good tuner in the hands of a competent human tuner. There are some, and you seem to be included, who think the "piggyback" configuration is is an inherent deficiency, but it is not so in a functional sense. All that is necessary is to have a correct injector pulse-width applied at the correct time to achieve proper combustion, and you can achieve that equally with any of the flash-based tuners as well as the PCV.
My bad.
