Tuning question
Old Apr 13, 2010 | 07:40 PM
jackinthebox's Avatar
jackinthebox
Default Tuning question
I have a question, when you get your bike dynot tuned and still have your o2 sensors. So they tune it to have a baseline I think of something like 13.7/1 and its a straight line on that everyone post on the bottom of their dyno sheets what does that mean. Does that mean the bike is running at that afr at all ranges or does it still change with different throttle positions and that 13.7/1 afr is the what the o2 sensors are making changes off of instead of the stock 14.7/1. I guess my question is why is it so important that the afr runs nice and straight on the dyno run.
Old Apr 13, 2010 | 08:12 PM
geargrinder's Avatar
geargrinder
There are many definitions of a "dyno tune". What you see on a dyno sheet is only a wide open throttle dyno tune. At WOT, the tuner usually targets a 12.8 - 13.2 air/fuel ratio. However, this is the easy part, only about 5% of a complete dyno tune. A complete dyno tune is engine start, warm-up, idle, all cruising speeds and loads, and wide open throttle, setting ignition timing and air/fuel ratio, a good day's job. The non WOT tuning does not show up on a dyno sheet and separates a good tuner from a not so good tuner.
JeffJA
The Dyno Room
Nov 25, 2016 02:16 PM
prondas
Feb 3, 2013 09:03 AM
Green Machine 04
Exhaust System Topics
Oct 2, 2010 10:45 AM
hog95023
May 20, 2009 05:56 AM
HOGRIDA_06
Apr 11, 2008 06:22 PM
