Big builds
Old Apr 14, 2010 | 12:19 AM
Mark MPDC's Avatar
Mark MPDC
Default Big builds
I want to ask the forum a question of getting any kind of build from stock that should you maybe take it real easy so to speak for a while before you start riding it hard?
If in fact you should what are safe miles one should travel over before it is safe to start riding strong on the bike? I have heard some say you can ride right away any kind of way you want but then hear some say you should baby the motor first so what is true and what is not or are both suggestions true and if so under which kind of big build does one fit more of then the other.
Old Apr 14, 2010 | 12:27 AM
hog-doc's Avatar
hog-doc
http://www.mototuneusa.com/break_in_secrets.htm
Old Apr 14, 2010 | 01:20 AM
Mark MPDC's Avatar
Mark MPDC
Wow,
that is some great reading their,thanks for the information.
Old Apr 14, 2010 | 05:14 AM
VETERAN75's Avatar
VETERAN75
I think once you follow the break in procedure previously posted you can ride it like you want to, after the engine is warmed up.
Old Apr 14, 2010 | 05:20 AM
131tman's Avatar
131tman
Break it in on a dyno...dummy!
Old Apr 14, 2010 | 05:29 AM
NoKenDo's Avatar
NoKenDo
Although my build is far from "big", this is the exact procedure I
used. After seating the rings I rode the next couple hundred miles
varying the rpm range.Not staying at any given rpm for an extended
length if time.
Old Apr 14, 2010 | 08:34 AM
Gambler1's Avatar
Gambler1
Run it hard, don't lug it and you will be fine.
uride2
"The Florida Crew"
Jun 2, 2011 07:33 PM
Sallyman
Apr 18, 2011 08:39 PM
jtscuba02
Exhaust System Topics
19
Feb 11, 2008 08:58 AM
UltraKla$$ic
Nov 16, 2007 05:20 PM
74_ironhead
Ironhead
Oct 9, 2006 08:33 AM
