SE clutch spring -- Installed
Old Apr 17, 2010 | 04:05 PM
flhtupser's Avatar
flhtupser
Default SE clutch spring -- Installed
Dyno tuned my bike last week and the clutch was slipping. I installed the SE spring this am and it works. $31 and 1.5 hours later no more slip. The lever pull is around 30% harder but the action feels good. I used Dawgs method on the adjustment and it was spot on. This forum is great and gives one the confidence to do your own work. I used the manual for torque specs and it was an easy job. Thanks HD forums!
Old Apr 17, 2010 | 05:57 PM
flhtupser's Avatar
flhtupser
Yep. I like it!
Old Apr 17, 2010 | 06:50 PM
nytryder's Avatar
nytryder
Mine too! Big improvement over stock. Huge difference wish I had done it sooner. +1 on the people here!
Old Apr 17, 2010 | 07:00 PM
emwolb's Avatar
emwolb
i did the screamin eagle clutch spring over a month ago, and along with the screamin eagle compensator, it made a world of difference. my 96" motor was starting to slip a bit via the clutch. not any more though. and now that it's a 103, i'm thinking it was time for a stronger drive setup. good for you man. some of this stuff is doable at home, ain't it cool?
Old Apr 17, 2010 | 07:08 PM
mongomark's Avatar
mongomark
Well, I've got the VPC Clutch hub kit and I've ordered the clutch spring for a 2003 big twin and earlier with some new friction discs. This setup should be good for a 124" Jims while still keeping reasonable clutch lever pull. It's a little pricey though. $300 for the VPC from AIM, $35 for the spring, $120 for the discs and $25 for the gasket. I'll let you all know how it turns out (I've already installed the VPC)
Old Apr 18, 2010 | 07:30 AM
maineultraclassic's Avatar
maineultraclassic
The best combo is the SE clutch diaphragm spring, and the EZ pull kit ramps.......that gives you the same lever pull as stock but with the added pressure of the SE spring.
I've been running that combo for the past 2+ years and love it.........no slipping at all with a stock lever pull.
Steve
Old Apr 18, 2010 | 10:52 AM
flhtupser's Avatar
flhtupser
Having the '06 I had the easy pull stock clutch, but the new spring added harsher pull but not too bad. I'll get used to it I'm sure.
Old Apr 18, 2010 | 03:35 PM
nytryder's Avatar
nytryder
The EZ pull will be installed on Tues along with V&H True Duals and hopefully my final Dyno Tune. I really like the way the clutch hooks up now.
BourboncityTroy
11
Jan 8, 2015 11:34 AM
misfitJason
Jun 15, 2014 04:42 PM
missedem
May 4, 2014 10:22 PM
creep1
Aug 26, 2010 03:50 PM
lhcstreetbob
Jan 16, 2009 06:21 PM
