screamin eagle race clutch
Old Aug 21, 2010 | 01:46 PM
creep1's Avatar
creep1
Default screamin eagle race clutch
had the screamin eagle race clutch installed. lever is unbeleivably hard to pull. If I switch to hydraulic will this ease the pull ?
Old Aug 21, 2010 | 02:01 PM
parts eeter's Avatar
parts eeter
Hydraulic setups do tend to be easier to pull. You may try switching to a high quality clutch cable. It willl help. That SE Clutch will make a man out of you real quick. I got the SE spring in mine and its tough,but you will build up to it if you give it a month or 2.
Old Aug 21, 2010 | 02:39 PM
redrubicon2004's Avatar
redrubicon2004
I would sell it and go back to a stock type clutch. Unless you are running over 110hp, you dont need it. My 100hp 95" was fine with a SE spring and plates.
I am now using the SE plates and a SE spring with an easy pull clutch ramp setup. I also have a BDL ball bearing lock up pressure plate and the clutch pull is similar to stock. It holds just fine with 110hp and 123tq.
http://www.beltdrives.com/bblucl.html
You could also get the easy pull clutch ramps and try that.
Old Aug 21, 2010 | 02:58 PM
sharkey's Avatar
sharkey
I, too, have the SE pressure plate and it's a bit stronger pull...I wanted to put on a hydraulic clutch for aesthetic reasons but the techs advised me not to claiming the engagement wasn't very progressive; all at the end of the lever travel...
Old Aug 21, 2010 | 03:26 PM
creep1's Avatar
creep1
thats what im afraid of. spending the loot for a hydraulic setup and not advancing. Think i might go back to stock setup. bikes makin around 110 .
Old Aug 21, 2010 | 11:17 PM
redrubicon2004
Like I said, you could try the easy pull ramps. They are cheap and worth a shot. Part numbers 25605-00a and 25604-00a. They are about $20 total. Install is pretty easy.
Old Aug 22, 2010 | 06:11 AM
sniper77's Avatar
sniper77
Hydraulic clutches have little to no feel, either all of nothing.
Have you tried using the stock spring with the new clutch pack or vice versa?
Old Aug 25, 2010 | 08:26 AM
creep1's Avatar
creep1
So if I put the stock clutch springs in with the SE race pack I should feel a noticeable difference???
Old Aug 25, 2010 | 08:37 AM
paul s's Avatar
paul s
I have the Barnett clutch, It comes with 2 sets of springs so I staggered mine with 3 heavy and 3 light, I have more clutch than I need and the pull is not very much different from stock.
Old Aug 25, 2010 | 08:58 AM
creep1's Avatar
creep1
Thats a good idea, gonna try that stagger. Thanks. someone mentioned trying the harley easy pull clutch ramp but I think 07 and up come with that stock ??
