hd lowering shocks
Old Apr 21, 2010 | 08:38 AM
cirhere2's Avatar
cirhere2
Default hd lowering shocks
07 ultra how much do the hd shocks lower rider
and how easy are they to install
Old Apr 21, 2010 | 08:47 AM
Big Blue Bike II's Avatar
Big Blue Bike II
I believe the shocks are 1" shorter and install is quick. Undo the top and bottom bolts and remove the nut for the air line and reverse for the install.
BBB
Old Apr 21, 2010 | 10:09 AM
UltraClassicElectraGlide's Avatar
I installed them on my Ultra with no problems, so it must be an easy install. The shock is 1" shorter, but I don't think the bike sits a full 1" shorter when installed. It's the same shock as on the Street Glide, which has 4.7" of ground clearance, compared to 5.1" with an Ultra. (Using 2010-model specifications.)
Note that you will have a firmer/harsher ride than stock, in part due to having to run higher air pressures so the shock doesn't bottom out so easily.
Instructions are at: http://www.harley-davidson.com/en_US...ts/-J04754.pdf
Old Apr 21, 2010 | 10:41 AM
mkeeping's Avatar
mkeeping
Default I bought these
I put these on last year and I lowered the front with progressive springs.
http://cgi.ebay.com/ebaymotors/CHROM...Q5fAccessories
Way cheaper than the harley shocks and I don't really notice much of a difference in the ride.
Old Apr 21, 2010 | 01:49 PM
JBELCHER7876's Avatar
JBELCHER7876
I am looking at lowering my bike too. I cannot decide if I should go with the 1 inch lower shocks or do the adjustable air ride.
Old Apr 21, 2010 | 02:00 PM
bdp's Avatar
bdp
I installed the SG shocks on my 08 and there wasn't much to it. I think you should use a jack to unload the suspension and then lower the bike down to get the bolts in the shorter shocks. Don't spill the fluid!!
Old Apr 21, 2010 | 02:03 PM
midwestboat's Avatar
midwestboat
[quote=JBELCHER7876;6600501]I am looking at lowering my bike too. I cannot decide if I should go with the 1 inch lower shocks or do the adjustable air ride.[/quote
I just lowered my 2008 streetglide 2 inchs. I bought the lowering kit from bikersdelight off ebay. I installed it in about 45 minutes using my stock shocks, it gives you 3 options, 1 inch 2 inch or 3inch. Very nice product cost $50 shipped to my door. Me and the wife went riding and noticed a little stiffer ride not much, wife didn't notice anything, but the stability and ease off backing up was awesome. Wish I would have done this a while ago.
matt_eglide
Mar 25, 2015 10:43 AM
ClassicRider99
Aug 26, 2014 12:05 PM
GEESE
Oct 28, 2013 06:49 AM
MikeK02048
Jun 25, 2012 09:13 PM
scooty
Jun 17, 2007 11:59 PM
