Oil Pan
Old Apr 24, 2010 | 10:53 PM
younggeezer's Avatar
younggeezer
Default Oil Pan
Has anyone pulled the oil pan on an '02 Ultra. Today I was changing out the oil filler neck for a chrome one, and one of the chrome washers somehow fell in the opening and into the oil pan. I thought about just leaving it in there, I doubt it will ever get sucked into the oil pump, but then I just can't take that chance.
Old Apr 24, 2010 | 11:16 PM
david christopher's Avatar
david christopher
the housing is aluminum and the washer is steel.....you should be able to use a magnet to get the washer out
Old Apr 25, 2010 | 02:55 AM
younggeezer
yeah, well, this washer is polished stainless! Just my luck!
Old Apr 25, 2010 | 06:33 AM
n8dc's Avatar
n8dc
Some stainless has magnetic properties .. check one of the other washers just to be sure ..
Old Apr 25, 2010 | 06:47 AM
mtairy biker's Avatar
mtairy biker
yea most stanless will hold a magnet . Only really good stanless won't . i bet that washer will.
Old Apr 25, 2010 | 06:59 AM
Dirty Dan's Avatar
Dirty Dan
pulled my pan after cam tensioners failed, just to see if any crap was in there, pain in the ***, getting the gasket to line up on the install was the worst, its an all day job but piece of mind for me was worth it
Old Apr 25, 2010 | 07:10 AM
dog155's Avatar
dog155
You really should take the pan down,the washer could end up in front of the pickup and restrict oil flow.You just never know,better to be safe than sorry.
Old Apr 25, 2010 | 07:37 AM
voodoodrug's Avatar
voodoodrug
had that happen in primary:O bite the bullet(u will sleep better)
Old Apr 25, 2010 | 01:49 PM
hog-doc's Avatar
hog-doc
Pulled lots of them, need to pull rear wheel then all the pan bolts. If the frame cross member is bent you will need to straighten it or the pan wont come out. There are 2 springs on top of the baffle that make it a little difficult but just work it back slowly. When replacing it put some Hylomar on the pan to stick the gasket in place.
harleyjohn45
Flathead
Jul 13, 2010 11:38 PM
Ultradoug
Aug 22, 2008 03:35 PM
mike_oh
Jan 20, 2008 07:35 AM
Timex
Aug 20, 2006 09:23 PM
