Sticky mess
Old Apr 25, 2010 | 12:47 PM
Roadie09's Avatar
Roadie09
Default Sticky mess
I just finished cleaning up the "Glue" that the MOCO thought would hold the rubber trim around the inner fairing on my RG. This snot is worthless, took me about an hour to clean it from the outer fairing, inner fairing and inside and outside the trim pieces. It was literally everywhere.
The MOCO should find the purchaser that agreed to use this product and kick them in the ***** (if they have any) everyday until they find another adhesive!
Old Apr 25, 2010 | 12:57 PM
MINI SSS's Avatar
MINI SSS
What did you use as a solvent that would'nt ruin the paint or blemish the raw plastic inner fairing? And yes, it's poor quality control.
Old Apr 25, 2010 | 01:27 PM
hog-doc's Avatar
hog-doc
Thats funny, its no good but took forever to clean it off?!!!
Old Apr 25, 2010 | 01:59 PM
Roadie09's Avatar
Roadie09
I used Gumout carb cleaner sprayed on a rag, it did not hurt the inner plastic fairing or trim pieces. I would not recommend spraying directly on the items or painted portion. I used pledge and a lot of elbow grease to get it off the outer fairing.
Hog-Doc-yes this stuff is worthless in this application, in fact I cannot think of any use where it would actually be good in. It is basically like rubber cement that never sets when you pull off the trim piece it looks like gum stuck to the bottom of your shoe.
Old Apr 25, 2010 | 11:56 PM
hog-doc's Avatar
hog-doc
Carb cleaner WILL melt plastic if you spray just a little to much on a rag and wipe with it. Better to roll it off with your finger then use brake clean for the last of the residue, not as caustic, basically alcahol and does a good job with adhesives.
Never had a problem with the new glue on the trim pieces, much better than the old days when we had to try not to make a huge mess using silicone!
Old Apr 26, 2010 | 01:06 AM
2011 Road Glide Ultra's Avatar
I used my thumbnail and paper towels, then put door edge trim on - looks great, no glue!
Old Apr 26, 2010 | 08:26 AM
Roadie09's Avatar
Roadie09
I agree with you on the carb cleaner not being the best for plastic, that is why I was reluctant to mention it in my original post. I do not want anybody getting carried away and damaging the inner fairing. I tested it on the back side area and decided it would work for my purposes. But there should be a big CAUTION about spraying it wildly. (on a side note, I figured if it damaged the finish I would have a good excuse to get the inner painted anyway)
Old Apr 26, 2010 | 08:32 AM
Gliden's Avatar
Gliden
Use RTV (black) as a replacement. Just a lil bit....
Old Apr 26, 2010 | 10:37 AM
iclick's Avatar
iclick
I wonder if Goo-Gone might work. Gum comes off easier if you cool it, so applying some ice might help with removal, although that might be tedious if you have a lot of it to remove. Just speculating here.
Old Apr 26, 2010 | 11:46 AM
Jags93's Avatar
Jags93
I ruined the dash in my truck with the Goo-Gone stuff, using it lightly.
Exactly what trim piece are you referring to, the little door jam type trim between the inner and outer fairing?
Mine seems ok
Motorboatn SOB
May 4, 2017 07:52 PM
KDUBYA
Powdercoat & Paint
Sep 13, 2014 09:03 AM
SPARKY01
Apr 6, 2011 10:45 AM
scot210
Jan 10, 2011 05:20 PM
Jukebox
Sep 3, 2010 09:55 PM
