oil change interval
Old Apr 25, 2010 | 07:42 PM
SG Mike's Avatar
SG Mike
I change my oil @ 7500 because I moved to Synthetic (Mobile 1). If the Dino is good for 5k then why not go another 2.5k on Synthetic?
Old Apr 25, 2010 | 07:43 PM
MarcV125's Avatar
MarcV125
Originally Posted by ashmarc
Exactly the same here. .......and we spell our name the same...
the C's have good taste lol
Old Apr 25, 2010 | 07:52 PM
sgnden's Avatar
sgnden
Originally Posted by MarcV125
Every 3 thousand miles. All three holes here. Synthetic Mobil 1 20-50. Redline shock proof in the tranny, and redline primary..
Idk why. Probably a piece of mind thing lol.
+1 except I go around 4k miles between...
Old Apr 25, 2010 | 07:57 PM
Crusing's Avatar
Crusing
As recommended by Harley, every 5k. Was using Amsoil, but marketing is a pain so I now use Moble 1.
Old Apr 25, 2010 | 09:20 PM
Little Mike's Avatar
Little Mike
Every 3k with Mobil1 20/50 syn in the engine and primary and redline shockproof in the tranny. I have also used royal purple synthetic gear lube in the tranny before I could get the redline and it worked well also.
Old Apr 25, 2010 | 09:23 PM
lh4x4's Avatar
lh4x4
5K or one year. Amsoil says 30,000 miles or 1 YEAR. The same with any car what ever miles they state or 1 year.
So change at any miles that you want or 12 months.
Old Apr 25, 2010 | 09:59 PM
sonar_chris's Avatar
sonar_chris
5K motor
10K primary
20K transmission.
For those of you that change all 3 holes every 5K or less, do you do then same thing with your cars or trucks? If so, why not change your engine, transmission and differential oil that often?
Old Apr 25, 2010 | 10:05 PM
hog-doc's Avatar
hog-doc
Originally Posted by sonar_chris
5K motor
10K primary
20K transmission.
So your gonna start this crap again here? You didnt finish your last argument over oil changes!
Old Apr 25, 2010 | 11:03 PM
Trek's Avatar
Trek
5K all three holes; amsoil; like to check the clutch, see what's happening. Transmission oil always looks like new, but 9 dollars for a quart...cheap insurance. Primary oil oils looks a bit dark and I like to keep things fresh around the clutch and the thingbob around the crank thingy the front of the primary dodad...
Old Apr 26, 2010 | 12:35 AM
Harleyboyddk's Avatar
Harleyboyddk
5,000 all three holes, same as everyone else I guess.
