RoadGlide headlight problem
Old Aug 14, 2006 | 12:25 AM
harley0711's Avatar
harley0711
Default RE: RoadGlide headlight problem
If I am guessin right roady is talking about steel self tapping screws into plastic???? not real sure - waiting for his reply - I do agree with the blue loctite on steel to steel
Old Aug 14, 2006 | 07:54 AM
roady's Avatar
roady
I was refering to the 4-13mm nuts that are in the inside of the fairing after you take the outer off. I believe that they hold the inner to the frame. There was no locktite on the nuts from the factory but there is now. I agree with you all on locktite make sure you get the big bottle of blue. Sorry I didnt reply sooner but finished doing some things around the house and then went to bed.
Old Aug 14, 2006 | 12:32 PM
harley0711's Avatar
harley0711
Thanks for the reply = amazed the shop did not see that before... I am in the process of doing the swap - the correct nuts for that area are steel locking - I will be sure to add some blue to them before I add the outer fairing...
Old Aug 14, 2006 | 12:59 PM
roady's Avatar
roady
Makes me think shop didnt even really look!!! It doesnt suprise me though.
Old Aug 1, 2007 | 07:39 PM
FLTR Cowboy's Avatar
FLTR Cowboy
6th Gear
I know this post is a year old but I have a question about removing the outer protective lens over my roadie's headlights. I have a 07 Roadie and the headlights have two bar & shield emblems in front of the headlight and behind the lens. Six months old and 2,600 miles and the glue has give out. So both my emblems are sliding around behind the lens. So here's the question, are the instructions here for removing the outer lens cover? You just carefully remove the cover from the front of the bike without removing anything else? It sounds easy if it is. Also has anyone else had this issue or am I just lucky?
Cowboy
Old Aug 1, 2007 | 08:03 PM
Blackisfast's Avatar
Blackisfast
Yup...the part above about easing the bottom tabs out...use a flat screwdriver with a rag over it, get the bottom two tabs out and then ease out the top ones. Nothing to it, simply snaps back in place.
Old Aug 1, 2007 | 08:11 PM
EasternSP's Avatar
EasternSP
Hmmm, I have had my fairing apart a few times now to install a garage door opener and I never thought to look at the mounting bolts on the frame extension. Ya got me concerned now.
Old Aug 3, 2007 | 09:03 PM
nedster's Avatar
nedster
I was out onenight and hit the high beams and that blew a fuse. Harley fused the high and low beam together. Replaced it and no problems since then. No reason ever found.
Old Aug 4, 2007 | 12:01 AM
Pearl Glide's Avatar
Pearl Glide
The four nuts on the inner fairing for the turn signals.
Old Aug 4, 2007 | 06:28 AM
roady's Avatar
roady
No it is not the nuts for the turn signals. The 4 13 mm nuts hold the inner fairing to the frame they are behind the headlight and below the radio.
