Smart Security System !!Help!!
Old Apr 26, 2010 | 03:36 PM
mrsr71's Avatar
mrsr71
Exclamation Smart Security System !!Help!!
I’m currently traveling and have run into a problem. The only way I can start my ’07 FLHX is to disarm the security system by utilizing the PIN code I originally put in when the bike was purchased new.
Once I get it started, run for a few minutes, and turn the ignition off, the systems re-arms and will not start unless I go through the process of utilizing the PIN code again.
The battery in the key fob reads 3.3 volts so I’m assuming that’s not the problem.
This all started after loading the bike into an enclosed trailer and putting the alarm in the “Transport Mode.” The owner’s manual states that to exit the transport mode, turn on the ignition and flip the run/off switch to run and it will automatically disarm. This is not happening.
Can someone provide any input to help resolve this problem? The nearest dealer is 300 miles away!!
Thanks….Dan
Old Apr 26, 2010 | 05:42 PM
Big Blue Bike II's Avatar
Big Blue Bike II
Dan,
Here is what my 2005 book says:
1: use the key fob to disarm the vehicle
2: turn ign key on
3ress and hold key fob button until confirmation is received - 3 flashes turn signals
4:turn ign key off
5ress and hold key fob button until confirmation is received - 3 flashes turn signals
Hope that helps
BBB
Old Apr 26, 2010 | 05:43 PM
Big Blue Bike II
I have no idea where the icons came from - should read press
BBB
Old Apr 26, 2010 | 07:37 PM
chasswartz's Avatar
chasswartz
Two things I would try, don't know if it would work. Put the fob as close to the alarm antenna as you can. Its located under the seat on the right side. If that does't work try pulling the maxi fuse for 30 seconds. Also go thru the procedure to put it in transport mode and then take it back out. Good luck
Old Apr 26, 2010 | 07:55 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
to exit transprt mode the fob must be present, i would still try a new battery they get soft after 2 years.
Old Apr 27, 2010 | 03:23 PM
mrsr71's Avatar
mrsr71
Thanks for the tips. When it stops snowing I'll give them a try and report back with the rusults.
Old Apr 27, 2010 | 07:00 PM
MI_Jim's Avatar
MI_Jim
One more thing to try would be to clean the battery contacts in the fob with a pencil eraser. A good battery & dirty contacts could act like a low battery and cause the problems you're having.
I buy my batteries on eBay. You can get 10 new Energizers for around $8.00 shipped.
jonesml
May 16, 2015 10:57 PM
Lucy
Aug 7, 2011 11:41 PM
Lucy
Aug 6, 2011 10:42 PM
icebite1
Oct 28, 2010 03:50 PM
Spanish Flyer
Dec 29, 2007 04:46 PM
