F@#KING RISER COVER Help Me
Old Apr 29, 2010 | 10:33 AM
Airborne314's Avatar
Airborne314
Well the washer swap didnt work... ****. I really dont want to put the stock bushings back on...
Old Apr 29, 2010 | 10:49 AM
LEGENDCHROME's Avatar
LEGENDCHROME
I would try swaping out the top washers (they seem really thick) and try using the stock two piece riser clamp, alot of times the new thick clamps are an issue.
Old Apr 29, 2010 | 11:37 AM
Airborne314
I did switch the top and bottom washers. I paid $175 for these freakin risers and according to carlini's web site it says will fit under stock Road King cover??? Im calling Carlini and hope they have the solution to this problem.
Thanks guys and keep it coming in case they dont have the answer I need. I know there is someone on here that had and fixed this issue. Is the stock bushings the only option? Thanks
Old Apr 29, 2010 | 11:42 AM
LEGENDCHROME
did you try switching the top clamp?
Old Apr 29, 2010 | 11:52 AM
Airborne314
That wont work, Im using 1.5" carlini bars and they have no step down.
Old Apr 29, 2010 | 11:57 AM
DGlide04's Avatar
DGlide04
With apes installed you do not want to mess with the 2 piece stock clamps. If Carlini doesn't say anything about this in their directions, take a look at the Wild 1 website, the stock 2-piece clamp may be okay for stock low rise bars, but apes put way too much stress on the skimpy 2-piece stock ones.
As far as the cover goes, I replaced the stock bushings on my '04 RK with the newer poly bushings from HD and the directions specifically said not to reuse the stock or any other washers, the HD poly bushings had caps already installed. I don't know about the ones you got, I've never seen Carlini bushings.
Just my $.02, hope that helps.
Old Apr 29, 2010 | 12:40 PM
LEGENDCHROME
+1 on not using the two piece clamp, I was suggesting trying the clamp to see if thats where the clearance issues lie. If they did fix it then I would suggest a thinner one piece clamp. I also have used the HD poly bushings on a number of builds and the one thing I really like is that chrome cover that they come with, I havent used the carlini bushings before.
Old Apr 29, 2010 | 01:56 PM
Airborne314
Well I called Carlini and they said to use a cover from a 2007 or earlier road king.. Guess I will try that? Another $89 ............... F#$K
Old Apr 29, 2010 | 01:58 PM
LEGENDCHROME
awesome...may phone your local dealer and see if they have a take-off they are looking to sell..
Old Apr 30, 2010 | 07:11 AM
Airborne314
It worked!! Called all the local dealers and I found one. Had to drive 2 hrs to get it but it is here and on the bike. Thanks to all of you for your help. I will post up some pics later today, it is raining here so wont be that great.
Thanks again
trideer
Milwaukee Eight (M8)
Jun 29, 2019 01:36 AM
thelawnmowerman
Sep 5, 2011 03:16 PM
Xtremerider112
Apr 10, 2011 09:06 AM
Robcat
Feb 27, 2011 10:59 AM
cathead2
Oct 18, 2010 11:42 PM
