Tail light quit working
Old May 2, 2010 | 06:32 PM
Daytona Glider's Avatar
Daytona Glider
Default Tail light quit working
Hey guys
I have a 2007 Roadglide, recently the taillight just quit working, but the headlight, turn signals and brake light works. I have checked the fuses, the battery cable and all connections I can think of. I did a search here before writing this. I have a stock taillight but I have the smoked lens with the red bulb. I looked at the old bulb and the new one I just bought and they look the same, no busted filament. Anyone have any idea.
Thanks
Old May 2, 2010 | 06:41 PM
1flhtk4me's Avatar
1flhtk4me
The tail light on my '06 did the same thing.
The fix was to crimp the socket a little with pliers.
Old May 2, 2010 | 07:24 PM
RandyDowdy's Avatar
RandyDowdy
Good idea. Also make sure there isn't an excess of lube in the socket. Usually light failures are ground problems.
Good luck, electrical issues are a biatch at time.
RD
Old May 2, 2010 | 07:52 PM
uncle bo's Avatar
uncle bo
if you have a test light.take the bulb out.find a good ground on the bike and see if there is power getting to the tab where the bulb mates with.if there is,then yes it is a grounding problem at the socket.this makes sure you are getting power to the socket.be carefull with the test light and make sure you don't hit the outsides of the socket.you could blow a bike fuse or your test light.
HarshMC
May 27, 2014 09:04 AM
cathead
Jun 16, 2013 07:18 PM
dcounterman
Aug 31, 2012 05:22 AM
JFonzka
Apr 24, 2008 06:46 PM
inkaholic
Nov 11, 2004 08:59 PM
