The Drag part you referenced is supplied by NAMZ. To make sure you could contact NAMZ at 610-265-7100 and ask them if it is one in the same. In any event, the WI distribution center for Drag has several on hand so if it is the same you would receive it the very next day from ordering if you ordered it from a dealer.
Emailed NAMZ got back to me in 2 min they said they are the same!!
Just posting to say the Drag part is actually the "housing" (the black connector, HD p/n 74116-98BK) AND the "socket lock" (HD p/n 74156-98. The socket lock is required to hold the wires in the housing/connector. HD uses two part nos.; Drag combines the two into a single p/n.
Carl
not the same
