Fork Oil Weight Question
Old May 7, 2010 | 09:19 AM
atrain68's Avatar
atrain68
Default Fork Oil Weight Question
I read through the fork oil posts and have a question. What are the weights of the following fork oils? I noticed there was some mixed info on this?
Stock Showa "Fish Oil" - The smelly black stuff that comes from the factory
Type E Fork Oil
SE Heavy
SE Extra Heavy
Thanks!
Old May 7, 2010 | 09:55 AM
Spur56's Avatar
Spur56
Harley will not really give a weight but:
Type E - 10 wt
SE heavy - 15 wt
SE extra - not sure. (20 wt?)
I mixed type E and Heavy, but the 2009 and 2010's have a higher spring rate, so you might want to go with SE HEavy for the best ride. It will make a big difference in the performance of the front suspension.
Old May 7, 2010 | 10:01 AM
xxxflhrci's Avatar
xxxflhrci
After dinging my front fender on the brake T, (Yes, it can and will happen if you hit the brakes and a hole at just the right time...It took me 40k miles to do it, though), I put in SE heavy. That took the dive outt the front end.
Old May 7, 2010 | 01:33 PM
atrain68's Avatar
atrain68
I switched to the SE Heavy last night and rode to work this morning. It was a very easy job to do.
I really like the feel of the ride. It is not rigid and reduce the front end dive to a much more acceptable level.
I asked the question in case I end up wanting a weight in between Type E and SE Heavy. I think I will ride a couple months with the SE Heavy and see how I like it from there. I can always mix with Type E and SE Heavy later.
SWThomas
Jan 16, 2015 02:06 PM
TRVSDAD
Mar 29, 2011 01:27 AM
Stickman53
Mar 13, 2011 09:49 PM
DocHarley
Jan 6, 2011 09:20 PM
Kevinm40
Aug 20, 2010 08:22 AM
