2008 FLHTCU Any one else have this happen
Old May 9, 2010 | 07:55 PM
bill1nat's Avatar
bill1nat
Default 2008 FLHTCU Any one else have this happen
Hi, I have an 2008 Ultra classic with a little over 6000 miles on it. It is still under warranty but I am curious if anyone else had this happen to them. It doesnt happen all the time but sometimes when i start it it idles very high ( 1300 to 1500 rpm) if i shut down and restart it will come down to 1000 to 1100 rpm even if the motor is hot. Does any one know the correct idle speed? Has anyone else experienced this? Thanks in advance for any help on this. Bill
Old May 9, 2010 | 08:01 PM
990rtracer's Avatar
990rtracer
Mine does that from time to time and I have way less miles, I have heard it is no big deal. I am not worried about it.
Old May 9, 2010 | 08:16 PM
saweet96's Avatar
saweet96
I have been told if you hold the throttle open (off idle) when you shut it off, this can happen.
Old May 9, 2010 | 08:35 PM
Dionicio's Avatar
Dionicio
If I remember correctly, turn the kill switch to run, then cycle the ignition switch four times on and off, allowing 10 seconds between cycles. This hopefully will reset Your Idle. As someone else mentioned allow the bike to come to full idle before shutting it down to advoid high idle.
Old May 9, 2010 | 10:23 PM
Ultra 2008's Avatar
Ultra 2008
Dionicio is 100% correct. I have a 2008 FLHTCU as well and experienced the same problem and received the on and off four times method from the local HD mechanic I use, as well as one of the local Indy's that I use from time to time.
joerose
Feb 6, 2015 03:12 AM
OPDSam30
Sep 29, 2012 10:35 AM
DaveWilliams
Dec 11, 2011 01:41 PM
dwg1956
Sep 22, 2010 11:54 AM
BCguy
May 16, 2009 06:43 PM
