10K Tune Up
Old May 10, 2010 | 06:12 PM
ScottyPotty's Avatar
ScottyPotty
Default 10K Tune Up
I have a 2006 Road King with 10K miles - is it worth paying $325.00 for this?
Old May 10, 2010 | 06:21 PM
cuda67bnl's Avatar
cuda67bnl
there's nothing there that you can't do yourself........ Save the $$$.
Old May 10, 2010 | 06:23 PM
1flhtk4me's Avatar
1flhtk4me
Not if you can do it yourself.
Old May 10, 2010 | 06:35 PM
Poacher13's Avatar
Poacher13
Not to hijack the thread but what all needs to
be done at 10K?
Old May 10, 2010 | 07:46 PM
glcash's Avatar
glcash
Im wondering too cause im almost at the 10k mark myself!
Old May 10, 2010 | 09:49 PM
ScottyPotty
Engine Oil & Filter
Inspect oil lines & break lines for leaks
Air Cleaner
Check Tires
Change Primary Oil
Check clutch Adj.
Primary chain adj.
Rear belt & sprocket
Throttle, brake, clutch controls
jiffy stand inspect/lube
fuel valve, lines, fittings inspect for leaks
brake fluid - check
check brakes
replace plugs
check electrical equipment
engine idle speed
steering head bearings - (this seems like an odd one???)
check air suspension
check windshield bushings
check cruise control
fuel door, tour-pak, saddle bags hinges - lube
critical fasteners - check tightness
engine mounts - inspect
Yeah - after going over the list it looks pretty basic. Dose anyone actually do the steering head bearings?
Old May 10, 2010 | 10:10 PM
Javawave's Avatar
Javawave
[QUOTE=ScottyPotty;6695486]Engine Oil & Filter
Air Cleaner
Check Tires
Change Primary Oil
Check clutch Adj.
Primary chain adj.
brake fluid - check
check brakes
replace plugs
engine idle speed
Yeah - after going over the list it looks pretty basic. Dose anyone actually do the steering head bearings?[/Q
Actually... yes. I had mine flat spot. if they wear or become loose you will get a tank slapper that will make you think you are going down on decel. It is rare they go bad, but something that should certainly be checked time to time. jmo
jvalus
Oct 10, 2018 12:23 PM
Bagged64
Motorcycles For Sale
Mar 27, 2015 11:44 PM
MJGomz
Apr 17, 2013 06:57 PM
ggrif
Jun 6, 2011 09:19 PM
91FLSTC
Aug 19, 2010 11:46 PM
