cruising RPM
Old May 13, 2010 | 07:21 PM
NoCoLoco's Avatar
NoCoLoco
The cruising "sweet spot" varies from bike to bike, it all depends on your particular set up and load. When in doubt, know that it's better to have the RPM's a little on the high side.
Old May 13, 2010 | 08:18 PM
Devo6684's Avatar
Devo6684
Originally Posted by Serge A. Storms
I need to get me a tach...
Since the King don't come with a no tach I am forced to play it by ear.
Usually maintain 40-45 mph in 3rd, 50-60 in 5th and 60+ in 6th.
Old May 13, 2010 | 09:14 PM
Clint55's Avatar
Clint55
Well said. I think the "sweet spot" is a great description. My opinion is that the "lugging" factor is more of a result of load vs torque rather than incorrect RPM's. Otherwise, we'd all be reving up to 2800 rms in neutral while waiting for that train or the long red light. Headwind, tailwind, uphill, downhill all make a huge difference in the "lug" factor. When I'm on the long downhill runs coming off Stevens Pass or North Cascades, I can keep the bike in 6th and well below 2500 rpm and I know it's not lugging.
Old May 13, 2010 | 10:21 PM
fxdwg_rugby's Avatar
fxdwg_rugby
3K is the best cruse 2500rpms is lugging!
Old May 15, 2010 | 06:07 AM
emwolb's Avatar
emwolb
i don't kick her into sixth gear till i'm above 65 mph, and it works for me.
Old May 15, 2010 | 06:52 AM
racerdj's Avatar
racerdj
I try to keep it around 2500 minimum. It seems to lug nearer to the 2000 rpm level.
Old May 15, 2010 | 11:35 AM
Harleyboyddk's Avatar
Harleyboyddk
2,500 rpm with any kind of load. Down to 2,000 if off the throttle.
Old May 15, 2010 | 11:42 AM
rkingw's Avatar
rkingw
Old May 15, 2010 | 11:50 AM
mile high king's Avatar
mile high king
I am on an 08 RKC, so I don't have a tach, but you really can just get used to the feel of the motor and drive-train to tell if it is starting to struggle or lug.....like allot of the posts have said. It really depends upon wether you have the bike under load....going up an incline, loaded down, into a headwind is going to be a different answer than cruising along on a level stretch of road. My bike has the taller 07-08 gearing, and I hear people say they can't use 6th below 80....that is so not true. It all depends upon the situation. I use 6th all the time from probably as low as 60 mph when the bike is on level cruise and not under load...it just purrs along....is a bike lugging when it is sitting still at idle?...of course not, and neither is it under a very light load. Tachs are great, and if I had one I would enjoy it I'm sure, but you also need to listen to and feel your bike.
Originally Posted by warrenrl
What RPM is to low to where you are lugging the motor?
Old May 15, 2010 | 01:38 PM
rushbass's Avatar
rushbass
Cruise at whatever shift point is listed in your owner's manual (load, wind, and terrain conditions permitting) and higher...
