Road king 5 speed transmission
Old May 16, 2010 | 09:05 AM
1999flhr's Avatar
1999flhr
Stage II
Default Road king 5 speed transmission
I have a 1999 Road King with a stock 5 speed transmission. Does anyone know, if I remove the transmission completely, will a 6 speed transmission from an 2008 bolt in directly, case and all, or are they different cases?
Old May 17, 2010 | 11:21 AM
HDSAE60's Avatar
HDSAE60
Default good one
I would also like too know about this
Old May 17, 2010 | 11:30 AM
07RoadHawg's Avatar
07RoadHawg
Interesting question. I can't answer about the case itself (although I'd assume it's different somewhat), but I know the clutch pack/ring gear/primary gear are different so I would guess that the trans input shaft is also different. Similar to how the engine crank output shaft is different for the compensator assembly to bolt up to. I know the primary housing is different, probably due to the differences in the clutch pack and compensator set up.
All that to say I don't know if the case is the same, but the guts and all that go along with it are most likely different. Is a SE 6 speed gearset or a Baker not an option?
Old May 17, 2010 | 04:17 PM
TXCHOP's Avatar
TXCHOP
Nope, not even close...
The primary bolt patttern is different. The oiling system is different...etc...etc....
gray horse
Sep 19, 2018 11:26 AM
WimDH
Jul 15, 2017 08:51 AM
Jash123
Engine Mechanical Topics
Aug 24, 2015 08:05 PM
Jash123
Aug 24, 2015 09:04 AM
OutToWinPAHC
Jun 17, 2010 11:13 AM
