Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Yes you can; however, why remove the trans when the internals can be replaced without removing the trans case?
There is a Primary/Transmission/Clutch/Drivetrain forum for related posts; might have gotten more and quicker response if your OP had been in that forum.
Here's what I see transpiring, You install a used tranny, roll it out of the driveway, take of down the street, and shell the used tranny. Best to get a new gear set.
The gears are totally shot I was figuring on just getting a used trainee and put it on
Tell us what happened, and how you determined the gears are totally shot.
Have you disassembled the transmission?
A new gearset from Harley is about 1500 bucks..
A used 5 speed low mileage gearset can be had for about 150-200 bucks that has been removed from someones transmission because they just had to have a 6 speed.
