Lowering kits
Old Aug 16, 2006 | 11:48 AM
Bagger97's Avatar
Bagger97
Default Lowering kits
Has anyone used the kit from Burly to lower the rear. I want to use one on a 07 Ultra.
Old Aug 16, 2006 | 11:56 AM
thugged's Avatar
thugged
Default RE: Lowering kits
Other than maybe having to space the top bag mounts out qtr. inch, you shouldn't have any problem.
Old Aug 16, 2006 | 12:03 PM
Mr Wonderful's Avatar
Mr Wonderful
I did. Works just fine....no changes in handling or ride quality. One point of info on this install: don't know about the '07 frame, but previous years have a "ridge" in the middle where the two halves of the Burly extension clamp on to. The "ridge" must be smoothed for the halves to mate properly and be a secure fit. You'll need a Dremel tool or a die -grinder for this task......grind away the "ridge".....be sure to get the bottom of the frame area, and be patient, taking as little material away as needed. It isn't much........trial fitting as you go. Once you are satisfied, remove the units, paint the exposed steel black, let dry and re-install.
Sounds like a lot of work, but it really isn't........took me maybe 2 hours.
Old Aug 16, 2006 | 12:08 PM
Bagger97's Avatar
Bagger97
ORIGINAL: Mr Wonderful
Is the ridge that needs to be ground down on the swingarm or the Burly kit?
Old Aug 16, 2006 | 12:20 PM
Mr Wonderful
ORIGINAL: Bagger97
Swingarm.
deeblues
Aug 8, 2011 11:28 PM
wbogan
Sep 7, 2009 07:24 AM
sharkeydude
Feb 26, 2008 12:17 AM
CLL375
Apr 23, 2007 10:02 PM
speeder75
Aug 10, 2006 02:05 PM
