Starter removal
Old May 19, 2010 | 01:23 PM
King SS's Avatar
King SS
Default Starter removal
I have to pull the primary to get a new belt on and I'm wondering if I have to pull the pipes to get the starter bolts out. Or is there another way to pull those two bolts out for the inner primay to come off? It's an 01 rk with stock pipes!
Old May 19, 2010 | 01:29 PM
Jinks's Avatar
Jinks
Try an extension, or an extension & a universal joint. That should get the bolts out, but not sure you can maneuver the starter around the pipe............
Old May 19, 2010 | 01:30 PM
dawg's Avatar
dawg
If you can finagle an allen wrench in there it will work. However, those bolts are on there tight and you would have a hard time turning the allen. Best way is to get the crossover pipe out of the way and use a long extension with allen head on a ratchet.
He only needs to remove the bolts to remove the primary, not pulling the starter out.
Old May 19, 2010 | 03:49 PM
hog-doc's Avatar
hog-doc
Long 1/4" ball allen and a long extension, dont need to take nuttin off to get to it.
Newharleylover
EVO
Mar 20, 2019 08:30 PM
jmn1960
Dec 13, 2014 06:37 PM
tsm1550
Jul 10, 2010 08:54 PM
hatchetman
Nov 2, 2008 10:54 PM
Jameson
Jul 7, 2007 04:16 PM
