CB question
Old May 20, 2010 | 08:23 AM
gambler's Avatar
gambler
Originally Posted by tedcmiller
A quick way to get volume adjustment for the CB is to push the squelch button. This will temporarily put the radio system in CB mode and the CB volume can then be adjusted separately from the AM/FM volume. Otherwise, select COM from the radio front panel. In the first case the system will automatically revert to what ever it was set to before the squelch button was pushed. In the second case, the system stays in COM mode. In both cases, the CB volume can be adjusted separately from the AM/FM volume.
Is this for the Harmon Kardon radios ('06 and later), or the earlier ones?
VA_Larry
Audio Systems
Apr 25, 2018 07:54 AM
Dirtball
Audio Systems
Mar 15, 2012 05:10 PM
jackja25
Mar 10, 2008 02:50 PM
Traceman
Aug 26, 2006 10:10 AM
Traceman
Aug 25, 2006 11:38 PM
