Axle Nut Torque Adapter 06' Touring
Old Aug 24, 2006 | 08:57 PM
wedgewood1's Avatar
wedgewood1
Default Axle Nut Torque Adapter 06' Touring
I adjusted my drive belt last time, but I had to remove my right side muffler to torque the axle nut. Just wondering if you know where I could get this type of tool, or possibly doing it another way. The MOCO will not sell me this tool, since I'm not a Harley Mechanic, and Kent-Moore resricted selling any to the public. Thanks In advance for any advice.
Old Aug 24, 2006 | 11:02 PM
SteveO's Avatar
SteveO
Default RE: Axle Nut Torque Adapter 06' Touring
I use a 36MM 1/2" craftsman socket and a torque wrench on the right side, either an adjustable wrench or the special wrench in the tool kit to hold the weld nut on the left side (using my left foot). Torque to 95-105 ft lbs. I also have the HD belt tension guage, works great.
Steve
Old Aug 25, 2006 | 08:06 PM
T.C's Avatar
T.C
Dont know if this tools avail. But tool trucks do sell kent moore tools, snap on, matco,mac etc.
Old Aug 25, 2006 | 11:08 PM
Tech2's Avatar
Tech2
Yeah, I found that out also. They have no problem selling the tool to measure belt tension, but won't sell you the proper torque wrench extension to do the adjustment correctly. I have alread decided that when I finally do need one, I'll just cut one end off of a Craftsman open-end wrench and have my buddy weld a 1/2"-drive socket to the side, or something like that. I'll figure it out when the time comes.
Old Aug 26, 2006 | 12:19 AM
ultraclassic137's Avatar
ultraclassic137
Just drop the two bolts out of the muffler hangers, pull the mufflers down with a tie down strap and use your 36mm socket and torque wrench. Don't need any other tools than those. PM me if you want a more detailed description of the steps.
Old Aug 26, 2006 | 11:32 AM
One_Screamin_Eagle's Avatar
One_Screamin_Eagle
ORIGINAL: wedgewood1
Just go to a different dealer or buy it from an online dealer.
Old Aug 26, 2006 | 12:29 PM
aquaskiman's Avatar
aquaskiman
Drag specialties sells a real neat ratcheting box wrench for the axel nuts. You can put a torque wrench on it and it works with out loosing your mufflers.
George
Old Aug 27, 2006 | 12:39 PM
RonH's Avatar
RonH
ORIGINAL: aquaskiman
George
Here's the same tool for 1/2 the price:
http://www.tooldiscounter.com/ItemDi...gle&kw=KAS9636
Old Aug 27, 2006 | 10:50 PM
wedgewood1's Avatar
wedgewood1
Thanks RonH, I think I'm going with that one nice tool!!
Old May 19, 2010 | 12:43 PM
tcbpat's Avatar
tcbpat
Stage I
Wedgewood1....
Posse 36 Rear Axle Nut Wrench $22.95 plus s/h Call Toll free 1-866-4476773
Info. info@pitposse.com
Pit Posse Motorsports
Hope this helps. I just ordered one for our 06 FLHRC
