Oil Temp-What do you do WHEN?
Old May 21, 2010 | 07:48 PM
wldbill's Avatar
wldbill
Default Oil Temp-What do you do WHEN?
I ride a 2009 FLTR, no oil cooler and no engine mods of any kind including aircleaner and exhaust.
I have the dash mounted oil temp gauge with the sensor installed at the front of the oil pan next to the
drain plug. The gauge is then indicating the oil temp as it is being picked up by the oil pump after some
cooling effect in the pan.
I did a 7700 mile road trip the last 2 weeks of April and the 1st week of May. There were many days when
the oil temp ran about 130 and never got above 145. The warmest it ran this trip was about 190.
So my question is what do you do when the oil temp never comes up to operating temperature, which is?
AND, do you ever pull your bike over and park it when it's running a high oil temp? What is that temp?
Old May 21, 2010 | 08:00 PM
swoopjr's Avatar
swoopjr
That doesn't sound right to me. Mine ran about 230 before the oil cooler, even in the cooler weather.It runs about 210 now with the cooler. Mine is bone stock also.
Old May 21, 2010 | 08:04 PM
Tucson_Tim's Avatar
Tucson_Tim
My BTs run about 230. I just got an OEM H-D oil cooler and plan to install it soon on the Deluxe. We'll see after that.
Old May 21, 2010 | 08:30 PM
NoCoLoco's Avatar
NoCoLoco
With a twin cam, you want your oil temp to be between 180-230F under normal riding conditions. If your oil temp can't even hit 180 then there's a problem, probably a faulty temp gauge. As far as being "too hot", I wouldn't pull over until it hit 300.
Old May 21, 2010 | 08:36 PM
Jinks's Avatar
Jinks
How many miles total on the bike? How many miles without the oil temp gauge? Does the bike run any different now that you can see a representation of the oil temp?
Old May 21, 2010 | 08:47 PM
Sancho's Avatar
Sancho
No one is considering outside air temp. My '01 ultra ran 125-130 deg hotter than ambient.
My 2010 runs 130-135 deg hotter than ambient. That's on the highway. Both had oil coolers. today I rode in 93 deg temps and my oil temp was 224, highway riding 70-75 mph.
Tucson_Tim's Avatar
Tucson_Tim
From what I've read, dino oil starts to break down around 250 whereas synthetic oil starts to break down at 300.
Old May 21, 2010 | 08:51 PM
cdesero's Avatar
cdesero
I just installed a HD oil temp fairing mount gauge. What i found on a few rides was the gauge is very acurate my runs about 185 oil temp with 70 deg air temp riding 55mph out in the sticks . i checked it with a lazer temp gun twice on two different rides by checking the temp on the oil pan next to the sending unit it was within 3 deg . One thing i did notice was it take a long time for your oil to come up to temp . Oh by the way i don't have a oil cooler .
Old May 21, 2010 | 09:00 PM
wldbill's Avatar
wldbill
I think the low oil temp was strictly a function of ambient air temperature, hi 20s to mid 40s, during the ride.
Oil temp was installed at 6k and with temps in the 60s the bike would take 20 miles to reach 180. This was the norm.
In stop & go traffic in KC, MO last September, she spiked right up to 245 or better and it took a bit of fast running
to bring her back down.
The bike now has 21k and I think the readings are pretty much normal for the air temps in which we were riding.
My point is, of what use is oil temp knowledge if the bike is going to continue to be ridden with low or high readings?
Old May 21, 2010 | 09:03 PM
wldbill's Avatar
wldbill
Agree totally that it's ambient that dictates where that gauge is going sit. While rolling along, at least. Then, I don't
think an oil cooler is going to help in the least when trapped in stop & go traffic and the temps are in the 90-100s.
