WTF Ever hear this
Old May 23, 2010 | 09:20 AM
trackadaptor's Avatar
trackadaptor
Unhappy WTF Ever hear this
Pulled my Spark Plugs: Gap set at .040
Rear plug: looks as something was hitting it....the bottom part has nicks and pits ???
Any thoughts ???
Old May 23, 2010 | 10:24 AM
FX4's Avatar
FX4
Pre-detonation, you're pinging.
Old May 23, 2010 | 10:35 AM
NMNSG08's Avatar
NMNSG08
+1 on pre-detonation.
Old May 23, 2010 | 11:27 AM
RK4ME's Avatar
RK4ME
Or maybe pre-ignition, also known as detonation or pinging. I haven't encountered that in a long time but I think I would reduce the gap to .035 on the new plugs and check them after a few hundred miles, or enrich the fuel/air mix and have a better, cooler running bike.
Old May 23, 2010 | 01:31 PM
trackadaptor
Cool Colder NGK DCPR8E
Plug Gap Spec. is .038 - .043 Went to a colder plug NGK DCPR8E .040 gap
Got this off the net:
http://www.ngksparkplugs.com/tech_su...2.asp?mode=nml
Pre-ignition
Pre-ignition occurs when the air-fuel mixture is ignited by a hot object / area in the combustion chamber before the timed spark event occurs.
When the spark plug firing end (tip) temperature exceeds 800°C, pre-ignition originating from the overheated insulator ceramic can occur.
Is most often caused by the wrong (too hot) heat range spark plug, and/or over-advanced ignition timing. An improperly installed (insufficient torque) spark plug can also result in pre-ignition due to inadequate heat transfer.
Pre-ignition will dramatically raise the cylinder temperature and pressure and can melt and hole pistons, burn valves, etc.
Old May 23, 2010 | 01:42 PM
RandyDowdy's Avatar
RandyDowdy
What brand of plug do most of you guys use? I have autolites in my Sporty, but my Father always ran NGK. I know some running the platinum quads. Does it really make a difference? And what heat range would a stock 883 (with S&S E) be most happy with?
Glad I saw this thread, still learning about pinging. My HD is running fine, just wondering what the most popular opinion is.
Thanx in advance, RD.
Old May 23, 2010 | 02:30 PM
deadhead111469's Avatar
deadhead111469
I've run both NGK and Autolites and have no complaints about either. NGK's in the carb'ed sporty and Autolites on the EFI bikes.
Old May 23, 2010 | 03:26 PM
J2X's Avatar
J2X
NGK seems to be a good plug.
Old May 23, 2010 | 03:28 PM
Sgt. Fury's Avatar
Sgt. Fury
I run autolites in mine. Had a little pinging with the hd ones, but no problems with the autolites.
Old May 23, 2010 | 03:29 PM
Beemervet's Avatar
Beemervet
Hi Jack..........
This thread isn't about spark plugs, it's about the real damage that riding while pinging will cause.
