Neutral Light Question
Old May 23, 2010 | 06:12 PM
flhtupser's Avatar
flhtupser
Default Neutral Light Question
'07 Ultra. 2nd through 5th gear the neutral light stays on. 1st it goes out. When I hit 6th it goes out most times. Sometimes it stays on in 6th. WTF? Any ideas? Dawg? Is it the switch? If anyone has had this and found a fix,let me know. Thanks!!!!
Old May 23, 2010 | 06:36 PM
dawg's Avatar
dawg
Check the neutral indicator switch at the top of the tranny. Might be bad.
Old May 23, 2010 | 06:38 PM
flhtupser's Avatar
flhtupser
Originally Posted by dawg
Check the neutral switch at the top of the tranny.
Should I clean it with contact cleaner? Or check it how?
Old May 23, 2010 | 06:40 PM
Olde Skool's Avatar
Olde Skool
Mine was doing the same thing quite some time ago. Replaced the switch under warranty and presto, problem solved...
flhtupser's Avatar
flhtupser
Oh,and Dawg am I glad you were F)&^$%g with us. You are way too valuable to up and leave this forum. Thanks!!
dawg's Avatar
dawg
If it is bad, it's only a $16 part. 33926-06B $15.85
Old May 23, 2010 | 08:59 PM
flhtupser's Avatar
flhtupser
Thanks. Thats a no brainer.
VooDoo13
May 24, 2013 10:32 AM
skydrifter
Jan 22, 2010 03:42 PM
yso191
Sep 13, 2009 09:09 PM
msmith
Jul 28, 2009 08:34 AM
Trojan_Hog
Jun 30, 2007 09:06 AM
