08 bagger wobble fixed!!!!!!!!!!!!!!
Old May 28, 2010 | 03:47 PM
chaswood's Avatar
chaswood
Default 08 bagger wobble fixed!!!!!!!!!!!!!!
Hey guys just wanted to say thanks to the guys on one of the threads about bagger wobble...dont remember who ...doh.. I checked my back wheel with an 8ft aluminm straigt edge by jacking the bike up ( pit bull lift) and runnung it across the back wheel projecting it foward and discoverd that they where out 5/8 of an in... So i loosend the front motor mount and adj the top and bottom stabilizers (same amount of turns) and using a big screw driver to releave preasure on the bottom motor mount i lined it up.. Tightend the mounts and links. I used the manual for the basic concept and tourqe specs but the mo co way is to much bull crap and special tools that u dont need.. I little comon sence can go a long way.. Any way the bike cruses at 100mph like its in f---in rails compaird to the way it used too at 85 and whipin allover the place... Good luck charlie
PS I ALWAYS HAD THE TRW BRACE AND IT HELPED WHEN I PUT IT ON BUT THE BIKE WAS STILL A LITTLE SQUARRLIE AT HIGH SPEEDS , I ALSO PUT IN STA-BOS BUSHINGS AND I THINK THEY DO WORK TO, THEY DO INCREASE THE VIBRATION, SO WHAT, THE END RESULT IS THAT THIS F---ER IS LIKE ITS GLUED TO THE ROAD!!!!!!!!!!!!!!!!!
Old May 28, 2010 | 03:52 PM
Mike's Avatar
Mike
Sweet! I haven't done the sta-bo bushings yet, but will probably do that too.
Old May 28, 2010 | 04:56 PM
VETERAN75's Avatar
VETERAN75
I am not sure how moving your motor would straghten out your rear wheel alignment. Can you be more specific and detailed please. I would like to check mine out.
Old May 28, 2010 | 05:38 PM
timbo141's Avatar
timbo141
Did you mean TWR Missing Link Stabilizer from Baggers Plus?
Old May 28, 2010 | 05:42 PM
chaswood's Avatar
chaswood
the motor and trans r connected to the rear swing arm. there is no adj at the swing arm. when u move the front mounts it moves the rear swing arm... if u have a brace on it i should take the link out and adj ur wheels them attach the bagger brace after, it may intefear with the adj.. thats how i did it,it works prefect..
Old May 28, 2010 | 05:45 PM
chaswood's Avatar
chaswood
the trw missing link it comes from canada.... u can get one , the guy i think is on this fourum, TRACY@ROGERS.COM.. good guy good product..
Old May 28, 2010 | 05:53 PM
brnew's Avatar
brnew
trw worked wonders for me too !
Old May 28, 2010 | 06:22 PM
VETERAN75's Avatar
VETERAN75
Thanks, I have been searching the forum. It appears to be in the service manual. I will check it out tomorrow.
Old May 29, 2010 | 04:24 PM
rinedog's Avatar
rinedog
2nd Gear
yes a lot of bikes require doin an alignment ive done it my self on mine, my bike suffered from seriouse bagger swagger i installed the glide pro parts and did an alignment and it was not even the same bike anymore, the glidepro fixes the real problem, good luck
Old May 29, 2010 | 08:59 PM
arthur's Avatar
arthur
Ditto on Glide Pro:
http://www.glide-pro.com/
Tjessie87
Oct 8, 2016 07:41 PM
james e penrose
Pacific
Jan 24, 2012 09:21 PM
chaswood
Touring Parts
May 31, 2010 11:29 AM
chaswood
May 28, 2010 03:04 PM
Stanger
May 13, 2007 09:44 PM
