spark plug wires
Old May 28, 2010 | 05:21 PM
smokntitan@Gmail.com's Avatar
Stage III
Default spark plug wires
Can i ask what is the best way to change the spark plug wires on a FLHTCUI? Does the gas tank have to come off in this case?
Old May 28, 2010 | 05:26 PM
NMNSG08's Avatar
NMNSG08
No the gas tank doesn't have to come off,but it is a pain in the ***!
Old May 28, 2010 | 06:02 PM
Stage III
thanks, guess i better take a day and gitter dun
Old May 28, 2010 | 06:58 PM
emwolb's Avatar
emwolb
smokintitan if it takes you a day to change spark plug wires on a big twin, then be sure to stick with your day job. just sayin. all you have to do is to loosen the rear attaching screw/bolt, whatever and block it up in the rear. this will give you access to the underside of the tank where the plug wires reside. of course, be sure to use towels to cushion the paint and chrome, that should go without having to mention though.
Old May 28, 2010 | 07:01 PM
emwolb's Avatar
emwolb
by the way man, welcome to the forum. lots of great information in here. all you have to do is engage your b.s. filter and you'll be just fine. you can tilt the tank upwards from the rear. be sure to not contact your steering head with the front of the tank though. it also depends on which year you're working with. some have a crossover line, i think that's prior to the bigger tanks used in 08 and newer though. the older ones do have a crossover line. and another tip. make sure you either siphon the gas into a gas can first. it might not seem like a big deal, but it's far easier when the tank is almost empty rather than full.
harley roadking
Oct 16, 2021 07:00 PM
Ndoggct
Sep 21, 2016 07:02 PM
bigpappa160
EVO
11
Feb 23, 2016 03:17 PM
MIBPreacher
Mar 5, 2012 05:35 PM
avalauncher
Jul 21, 2008 09:29 AM
