whine after tire change
Old May 29, 2010 | 09:57 PM
xbigmikex's Avatar
xbigmikex
Default whine after tire change
pulled rear wheel off took it to stealer ship had a new tire put on took off down the road and thought i heard a siren looked behind me and nothing its either the belt or tire are the dunlop d402 noisy new? could the belt be out of adjustment? we put it back the way it came off it rides and handles great
fishing for ideas
Old May 29, 2010 | 10:02 PM
Sgt. Fury's Avatar
Sgt. Fury
Check the tension on the belt. If it's tight, it will make noise.
Old May 29, 2010 | 10:09 PM
xbigmikex's Avatar
xbigmikex
if it is tight will to tight hurt it? will the noise die down a bit i do ride 2up and plan on it in the am this is my first belt drive bike all rest were drive shaft metrics
Old May 29, 2010 | 10:16 PM
Sgt. Fury's Avatar
Sgt. Fury
well tight is really not good for it. I would get a tension guage and make it right. They're not too expensive
Old May 29, 2010 | 10:29 PM
piasspj's Avatar
piasspj
If you don't have the tool try twisting the belt. You should be able to twist the belt 45 to 90 degrees. If you can't it is too tight.
The tension gauge isn't that expensive (H-D or other brands cost about the same) and is a good tool to have.
Did you get the spacers in right? A belt that isn't aligned properly could also make noise.
Old May 30, 2010 | 02:06 AM
CroK's Avatar
CroK
D402 on my bike always had a whine, especially when leaning left. Was louder when the tire was not correct pressure, but there at spec also. New E3 has no whine like the 402 had...
Old May 30, 2010 | 06:31 AM
cmhfguy's Avatar
cmhfguy
Belt tension, especially if it varies with rpm/speed
Old May 30, 2010 | 07:31 AM
xbigmikex's Avatar
xbigmikex
cool thanks for the info guys
Buff58
Sep 23, 2013 09:06 AM
chinookman
Nov 16, 2012 08:44 PM
MDER123
Oct 29, 2010 08:31 AM
rough rider
Sep 15, 2010 10:58 AM
2005UltraNC
Jun 29, 2006 09:38 PM
