+2 sweeper bars, quick review.
Old May 30, 2010 | 02:02 AM
akroguy's Avatar
akroguy
Thumbs up +2 sweeper bars, quick review.
I just put the sweepers on my ride yesterday and, so far, I really like them! Not only is the reach much more comfortable (elbows comfortably bent now), but the front end just feels lighter....more nimble. The balance of the fork assembly seems different now..more leverage with the grips being further from the pivot point. Grip angle is better and I'm able to lean back more. I'm 5'10", short torso, longish arms. Pretty much an ape.
I changed out the clutch cable to a plus 3", and the T/I cables +2. The T/I cables probably didn't need to be swapped out, and the new ones are actually a bit too long. But, while doing the job, having fresh cables made sense to me.
With the bars up as high as the inner faring will allow, my hands are still riding in quiet air, but maybe just a little bit more breeze over the knuckles and third/fourth finger areas. Still pretty comfortable there.
It was a lot of work, mainly in routing the cables and getting the clutch cover off without pulling the exhaust (it CAN be done!), but I'm glad I did it. That clutch cover can come off without draining the tranny or parking the bike on 2x6's. You'll dribble out a few tablespoonfulls of oil, but that's it. Just top it off or drain/fill and you're set. The inner snap ring on the clutch cable ramp is a b*tch to get off so have a sturdy snap ring plier set. My set of proto snap ring pliers just couldn't hack the job. After I got a beer into me, it finally succumbed. (Note to self: start cracking cold ones sooner in the project.)
Protect your tank during the teardown and install! You'll be dropping switch housings, levers and all sorts of other bling so watch out. Oh, and speaking of the tank, you can route the T/I cables without removing it. Yay. It might take a few tries, but a piece of coat hanger wire as a fish tape worked for me.
So, to summarize, the comfort factor is far superior vs. stock bars, at least for me. What really surprised me though is the improved FEEL of the steering. It is very much lighter and more nimble feeling now. Full lock, slow turns are a breeze. I'm no longer shoving the bars around, but almost finger-tipping them. The front wheel seems to fall over into the turn on its own more readily now.
Thanks to Berk, Dawg and many others for their great guidance on this project!
Old May 30, 2010 | 06:00 AM
lp's Avatar
lp
Did the same exact thing on the wifes bike yesterday. Great bars. Only wish they came up just a little more.
Did the 2x6 thing too. Guess I had the trans a little over filled. Got a little more than a spoon full!
Hope she (wife) likes them. She's on travel right now..
lp
Diesel Man
Dec 7, 2012 09:31 AM
03fxdx
Apr 4, 2012 01:27 PM
DocO
Nov 21, 2011 03:42 AM
wrightd
Aug 29, 2010 11:28 PM
sledhead140
Nov 3, 2008 09:21 AM
