Handle bar help
Old May 31, 2010 | 07:18 PM
dqroadhog's Avatar
dqroadhog
6th Gear
Default Handle bar help
put a set of 10"yaffe monkeybars on an 09 roadglide and with the bike clamped down on a lift the bars are slightly pointing to the right they line up with the instrument nacelle but gives the appearance the fairing is off is there any way to adjust anything to make everything look straight
Old May 31, 2010 | 07:23 PM
glide2005's Avatar
glide2005
Not sure, but it probably has been that way from the start. With the short stock bar, you just didn't notice it, but with the taller bars it shows up more. Just my .02
Old May 31, 2010 | 07:27 PM
dqroadhog's Avatar
dqroadhog
6th Gear
thats what i was thinking is there any way to align steering stem ? or is it something u cant fix
Old May 31, 2010 | 09:07 PM
vette's Avatar
vette
Loosen the two riser bolts a little and then u can twist the bars a little.
Tarkus60
Nov 12, 2016 09:58 PM
TwoBlue02
Aug 3, 2012 09:17 PM
Jukebox
Jan 24, 2010 09:51 PM
WIKD1
May 11, 2009 12:42 PM
HDF Tech
Jul 24, 2005 09:45 PM
