Fuel Overflow Question
Old Jun 7, 2010 | 10:19 PM
MexiRider's Avatar
MexiRider
Default Fuel Overflow Question
Ok folks,
I have an '07 RoadKing. After riding and needing to refuel, gas will leak from the gas cap. I don't overfill. I've read on this forum that the overflow tube is supposed to prevent this. I've also heard (not in this forum) that the overflow tube can get clogged and cause this symptom. So, I looked in my service manual and disassembled the dash to gain access to the entire tube route. I found that all the tubing was completely clear of any obstruction. The check valve, near the battery was functioning correctly. Blow air down and it goes through. Try to pull air back and it doesn't go.
Now, near the tank, there is what looks like a filter. Here's my question for you folks. Is this a one way filter? If so, which direction should it flow? When I removed it, the flow was toward the tank. If it's an overflow vent, shouldn't it flow AWAY from the tank?
I've looked in my manual and there is no mention of this "filter"
Thanks
Old Sep 2, 2012 | 08:36 PM
MexiRider's Avatar
MexiRider
Bump.
Old Sep 2, 2012 | 08:46 PM
btsom's Avatar
btsom
Once, after refueling, I loosened my cap to check something and got the same thing you describe. How tight are you twisting the cap? Re the filter, just a guess. Air must go into the tank as the fuel level goes down, perhaps this is an air filter to keep the tank from "inhaling" dust, and it won't let fumes out. I don't seem to have either of those gadgets on the vent tube of my 08 Road King, any chance you have a California spec machine?
Old Sep 3, 2012 | 09:49 AM
MexiRider's Avatar
MexiRider
Thanks for the reply. When I tighten the cap after refueling, I tighten it 3 clicks. It's not a California spec bike. I'll replace the filter just to see if that fixes the problem. I'm also considering getting a new cap or maybe just the gasket for the cap.
IrIeSpringer420
May 18, 2015 09:34 AM
Tedjay
May 20, 2013 08:34 PM
azhunter
Exhaust System Topics
Jun 11, 2012 09:00 AM
Grumkay
Feb 21, 2008 12:15 PM
crashbike310
Aug 7, 2007 01:58 AM
