GPS fastest vs shortest ???????
Both fastest and shortest can be a nuisance. In both cases you can be taken off a given road, down a shortcut, then back on to the road you just turned off! Arguably it would have been easier (not an available setting on these things!) to stay on the same road.
I have also travelled in company with Garmin users and they quickly disagree with TomTom on which route to take, as a result of which, on one of our trips, we set off on our own. It got rid of arguments over which was the correct way, especially after Garmin tried to send us down a dirt track!
So IMHO when buying a GPS the first purchase should actually be an up-todate map! The beauty of a GPS is that it always knows exactly where you are, but getting that info to you in a useful form is not their strong point.
GPS's are far from perfect. You REALLY have to get to know how they operate, the parameters used by the operating system and how you response to the messages given.
For example: you're on a main hwy and are approaching a long sweeping curve. Before the curve there's a hwy exit/entrance. If the GPS is programmed for shortest route; it might direct you to take the "exit" and then the "entrance" because that distance is "shorter" than the long curve. Believe me; it happens.
The PRIMARY lesson to learn is do not allow the GPS to REMOVE your Common Sense. Do not TRUST the GPS, businesses change location and not every program works flawlessly.
That's it for me.
Ride In Peace
That's it for me.
Ride In Peace
