Fix a flat
Old Jun 14, 2010 | 06:05 PM
kuma's Avatar
kuma
Yes slime is okay different chemicals doesnt work on the same principal.
Old Jun 14, 2010 | 06:17 PM
jimmything's Avatar
jimmything
I've heard of a couple places that seal the rim with a silicone type sealent. One even mentioned he used rhino liner to seal his. The only drawback is when the spokes need tightening, the seal will be broken. I'd like to give it a try though.
Old Jun 15, 2010 | 10:34 PM
Campingout's Avatar
Campingout
Originally Posted by dmacx
The wheels I have are the profile laced, chrome option. I am not sure if the standard wire spoked wheels are tubeless or not. If they are it is probably written on the sidewall.
Seems to be a pretty common misconception. I didn't mean to call you out, Camping. I only quoted you because it was in this thread.
No offense taken here, sir. I really do appreciate the info, and I read your later update. I had been looking at getting a Road King, and had ruled out the RK Custom or Classic, whatever it's called, because it comes with the spoked wheels.
I went ahead an bought a Night Rod Special instead, so the RK is moot now. But I try to stay up with technology in motorcycles. No way I'm going to be on the side of the road with a flat tire, when I can Fix-A-Flat it, and be on down the road. Been through it, and I ain't doing it again. And if that means buying a new tire because of it, well so be it.
Stay on the road.
Old Jun 15, 2010 | 11:47 PM
Other Sheep's Avatar
Other Sheep
It'll work six out of seven times. With tubes. The seventh time the valve stem had torn so nothing short of a new tube would make the repair. The other six times it was nice to be able to get home. And a new tube is not that expensive if you take the wheel in.
daveMD2011
Aug 3, 2011 04:53 PM
obonaven
Oct 8, 2010 08:14 AM
mtowner
Jun 17, 2010 11:33 AM
PoincianaRoadKing
Wheels/Tires
11
May 12, 2010 09:06 AM
Uncle Scrooge
Aug 26, 2008 09:23 AM
