Yet another Cam question
Old Jul 3, 2010 | 10:14 AM
dcfatboy's Avatar
dcfatboy
Originally Posted by jlacasci
2nd try at posting a photo.
Attachment 125838
What are the 2 RPM lines near where your graph crosses 80 ft-lbs of TQ?
Old Jul 4, 2010 | 12:03 AM
jlacasci's Avatar
jlacasci
Default 2 RPM Lines
I think what you are asking me is where does the torque lines cross at first going above 80 Torque and where does it cross going back down.
Note: if I'm reading this right since it shows two runs: Red lines are the
stock cams with the 95" kit from may 11.
Blue lines show the Andrews 21 with the 95" kit when dyno'd on 6/29.
So if I understand your question...
The first RPM at 80 torque is 2.75 RPM x 1000 the second where it crosses back down at 80 is at 4.60 RPM x 1000
Hey, I just realized what you were asking and now I understand why the bike feels like it has so much more power ;-)
Prior to the new cams the cross lines for 80 Torque were 3.20 and 4.30
My sweet spot is significantly larger where I ride, between 2500 and 3500 RPMS which is EXACTLY where I told the tuner that I rode.
Joe
Joe
Old Jul 4, 2010 | 12:16 AM
greatnorth47's Avatar
greatnorth47
Stage III
I have a 95 with andrews 37g, hang on when you grab a handful, pulls well with 2 up. rpm range works well up to 5200, and they come on line at 2100.
Old Jul 4, 2010 | 10:00 AM
jlacasci's Avatar
jlacasci
Default Andrews 21, 37 etc...
Since I know so little about this, but I am trying to learn...
I called Andrews and got to speak with an engineer. They were great by the way. I told them my riding style, mostly 2 up, 05 Ultra with 95" kit only and had stock cams. I was looking for torque to come on early. It was the
Andrews folks that told me to go with the 21.
Since I put in adjustable push rods, I now have the option to switch a bit more easily. Although I can't imaging changing anything any time soon.
Joe
Old Jul 4, 2010 | 11:49 AM
07RoadHawg's Avatar
07RoadHawg
Joe
LMAO. Famous last words.... Don't ask me how I know.
Old Jul 4, 2010 | 01:15 PM
FD2's Avatar
FD2
Hey, anyone know what the difference is between the Woods TW6 and the 6-6? Both appear to be cams for the twin cam and there is a slight difference in the numbers for duration at TDC??
Old Jul 4, 2010 | 01:29 PM
dcfatboy's Avatar
dcfatboy
Joe
Joe
Old Jul 4, 2010 | 01:55 PM
BigDaddyMike's Avatar
BigDaddyMike
My old 05 Road King had a 95 inch kit, SE flat top pistons, mild head work (ported) and a SE 204 cam. It was a strong puller from 1500 to 5000 rpm, just where I needed it. I loved the 204s and would recommend them without question in a 95 build looking for low end grunt.
Old Jul 4, 2010 | 01:57 PM
Mike's Avatar
Mike
The Woods 6 is a grind. The -6 suffix indicates it's for the 06+ dyna and 07+ touring bikes.
Old Jul 4, 2010 | 02:09 PM
Mike's Avatar
Mike
They also work great in a 96 or a 103. If you look at the specs, the 204 just like an Andrews 37 with a 4* advance.
I put them in my 103 along with 1.725 rockers to bring the effective lift to .539. Doing that also adds a couple of degrees duration and speeds up the ramps. If I raise my compression a bit, I can add a -4* gear, and with the high ratio rockers, they become much like the Andrews 54.
The 204 cams have one of the best grinds in the SE catalogue.
