New 98" build started
Old Jun 26, 2010 | 06:20 PM
  #31
1931jamesw's Avatar
1931jamesw
I agree. I don't think the cam is a weak link in your motor. I'm sure you're well aware of that cams capabilities. Are you running the 4 degree gear on it? Also, how dis you arrive at 98 cubes? What is your bore and stroke?
Old Jun 26, 2010 | 06:42 PM
  #32
cuda67bnl's Avatar
cuda67bnl
Not running the 4* gear. Stock stroke, Hillside's 98" Wiseco pistons (3.937 I think)
Video from today..... It's funny how much different it sounds through the camera, versus in person. At .38 in the video, you can briefly catch the 'tink' before I move the camera.
http://www.youtube.com/watch?v=HVNIACSHvl0
Old Jun 26, 2010 | 06:52 PM
  #33
1931jamesw's Avatar
1931jamesw
After seeing/listening to the new video and reading another thread here in this section, it makes me wonder if the rocker arms need shimming.
Here's a link to the thread: https://www.hdforums.com/forum/touri...-shimming.html
Old Jun 26, 2010 | 07:06 PM
  #34
cuda67bnl's Avatar
cuda67bnl
That's on the potential to-do list. Doesn't make sense that it wasn't there before the build though, and the endplay hasn't changed. But, the difference may be how far they're cocked to one side now, maybe? They're within spec, but then again, the moco's specs are pretty wide...... It's also crazy how much slop room there is in these motors. You can shift the rocker supports quite a bit in these things. I would've tried centering the supports like I did the lower boxes, but the alignment screws aren't long enough.
It's loaded in the trailer now for the trip to Florida tomorrow. Unless Doc thinks it's an issue, I'm gonna turn the radio on and ride the damn thing. I'll pull it back apart in a few weeks and do some shimming and go from there.
Old Jun 26, 2010 | 07:14 PM
  #35
1931jamesw's Avatar
1931jamesw
I've never met doc but from what I've heard about him, he knows what he's talking about. Probably a good call on your part to let him make the call on what to do next.
Old Jun 27, 2010 | 05:44 AM
  #36
akroguy's Avatar
akroguy
I'm hearing something tapping the rocker cover, almost like tapping the inside of the cover with a spoon. Got rocker supports all snugged down tight, cover screws, etc....? I had a similar goofy noise coming from an unused electrical connector that was dangling on the engine guard. Finally tucked the thing up into the fairing once I figured it out.
Pull the plugs and crank it via starter while listening closely to the rocker area. Maybe get the exhaust note out of the equation.
I dunno..just throwing out ideas. Man I hope my bike runs at least a tiny bit better after all the time and $$ I'm putting into it now. Freaky motor noises drive me nuts so I understand how frustrating this must be for you.
Hang in there.
Old Jun 29, 2010 | 11:19 AM
  #37
1931jamesw's Avatar
1931jamesw
Cuda, did you get all the kinks worked out?
Old Jun 29, 2010 | 06:23 PM
  #38
cuda67bnl's Avatar
cuda67bnl
Just got back home from Florida. It was an interesting trip, to say the least.......
As soon as I put the bike on the dyno and Doc got started, the battery crapped out. Ran to the local stealer and got a new one. $160......... He tuned for several hours, and I ran to get some lunch. When I got back, more bad news. The damn drive belt broke. He was pretty much done, and was doing some fine tuning with timing adjustments when the belt broke. So there's still a little power left in it. The next time I ride down to visit my dad, he's gonna finish tweaking it.
The curve is decent, with just one little spot to straighten out. That won't be a problem right now though. Stopped on the way home and bought a belt, so hopefully I'll be riding again tomorrow or the next day.
As for the mysterious noise, it seems to be better. The bike had cooled down a bit by the time I got back from lunch, but it sounded good then. Once I'm able to take it for a ride and get it hot again, we'll see how it sounds.
Got to give a big "f*ck you" to Stormy Hill H-D for their overpriced batteries. But have to give a big "kudos" to Chrystal River H-D for giving me a huge break on the new belt.
Most of all though, I need to give Mr. Wizard from this forum a HUGE thank you! His tremendous generousity made my trip a LOT easier and more comfortable. I owe you greatly, Wiz.
Old Jun 29, 2010 | 11:17 PM
  #39
1931jamesw's Avatar
1931jamesw
Hey man, those lines on your dyno sheet are as smooth as butter and it's making considerably more power than my 96" with 255 cams. I'm glad you got it all worked out.
Old Jun 30, 2010 | 08:11 PM
  #40
cuda67bnl's Avatar
cuda67bnl
Got the new belt on today. Bike runs quite nicely. Very smooth power throughout the range. Still gonna have to chase some top end noise though. It's a little noisier than I want. Guess I'll go back in and try shimming the rockers. I'm gonna be interested to see what kind of mileage I have, once I quit wicking the throttle.
Swingarm bushings are next on the to-do list. Mine didn't look too good today when I took everything apart. They were rather smooshed out of shape. That should help eliminate my slight handling woes.
Notz
Jun 17, 2013 10:35 PM
ajohnston78
Jul 14, 2011 07:54 PM
Puttnutt24
Sep 22, 2008 11:21 PM
6o66er
Apr 3, 2008 03:26 PM
07fxdwg
Jan 28, 2008 07:33 PM
