Odd speedo issue...anyone else notice this?
Old Jun 22, 2010 | 03:30 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Question Odd speedo issue...anyone else notice this?
Before I start, I'll admit to being a bit "A-R" about facts-data-numbers. Also, the extended speedo watching was done in minimal to no traffic...
Did the Hell's Canyon Rally 10-days ago. On the 400-mile (each way) route, we encountered a couple of the 5-mile Speedo/Odo Check Sections. Since this was my first long trip on the RKC, I was curious to see how accurate my odometer is.
I selected one of the Trip meters (so I could watch tenths). Because my encounter with the "Mile-0" sign did not exactly correspond with a "tenth" transition, I mentally counted to myself "thousand-one, thousand-two, thousand-three..." the time between the sign and the first "tenth" transition, since I was expecting much closer tracking between the two.
Over the five mile check, I found the miles rolling up faster on the trip meter than actual distance travelled, to the tune of about 4-percent when I did the math. I had my cruise set at about 60-mph, so I was expecting about six mental "thousand-one..." counts for every tenth of a mile transition.
The weird thing was that my 1-tenth to 2-tenth transition only lasted about 4-seconds (counts), and the 7 to 8 tenth transition was only 3. The 8 to 9 tenth time lasted a full 8-seconds...most of the rest were spot-on 6-seconds. This just struck me as odd, that a digital counting device could be so non-linear (though repeatable).
Old Jun 22, 2010 | 04:53 AM
kingkingking's Avatar
kingkingking
The HD speedos read faster than you are going, so it makes sense that the trip meter reads more than you have travelled.
As a bonus for HD if they make their odometers read 5% more than actual then the dealers up doing 5% more servicing.
Old Jun 22, 2010 | 04:59 AM
carltex's Avatar
carltex
Your right, your A/R. Does the same with a GPS. Bike says 77 GPS says 74.
Old Jun 22, 2010 | 05:13 AM
Wingnut51's Avatar
Wingnut51
I checked my '10 RKC with a GPS and found the speedometer was reading 5% high. If it's any consolation, my Honda VTX read 10% high. You'd think they could put an accurate speedometer in these things.
Old Jun 22, 2010 | 11:20 AM
dougbk's Avatar
dougbk
Typically off by 3 miles per hour. As HD Tech would say THAT IS NORMAL!
Old Jun 22, 2010 | 11:36 AM
will2002's Avatar
will2002
It all works out well for me I think. Keeps me from getting a few speeding tickets maybe.
Old Jun 22, 2010 | 11:43 AM
Texas Fat Boy's Avatar
Texas Fat Boy
What everybody else said. Here's what I've found.
'08 Street Glide speedo: 73
GPS Garmin 750 Nuvi: 70
'09 Street Glide speedo: 73
To compare:
'08 Buick Enclave speedo: 70
'08 Chrysler Aspen speedo: 70
Old Jun 22, 2010 | 12:15 PM
frog13's Avatar
frog13
Been covered several times on the forum if you search. It's a mechanical device and has to have some tolerance built in. The law says a speedo cannot read slower than travel speed, but it can read faster. Because of this the tolerance is something like +5%, -0%, allowing it to read faster, never slower. If you have a close tolerance speedo, you could be close to dead on. If it's outer limits on the tolerance it could vary at least 5%, maybe more depending on the spec.
Old Jun 23, 2010 | 05:03 AM
PKellyMc's Avatar
PKellyMc
Gotta disagree with the odometer being a mechanical device...LCD, no cable/worm-gear unit driven by the front wheel. I'm not concerned with the speedo reading faster than actual; my Wide Glide is the same. My point of concern was the discrepancy between the length of time (or number of pulses from whatever speedo sensor) between tenth-of-mile transitions when holding a steady speed.
Just never mind...I'm even starting to sound ridiculous to myself now.
Old Jun 23, 2010 | 05:27 AM
rocknrod's Avatar
rocknrod
Hmmm - If I were a HD Dealer I'd say those Garmins are reading slow
