Excessive Vibration - 2003 Bagger
Old Jun 30, 2010 | 06:02 AM
Road King Kid's Avatar
Road King Kid
Any time I can get a person on the phone to answer a question...............you get the idea!
[/QUOTE]
Agreed. Getting someone (that cares) on the phone is every bit as important as having a high quality solution. I bought the Glide over the Velva based on Jake alone.
Old Jun 30, 2010 | 08:27 AM
shootfirst83's Avatar
shootfirst83
Originally Posted by Road King Kid
How is the vibration at idle? Have you checked your aligment? Have you ever taken the rear swing arm off or loosened the shaft? Is this a new conition? How many miles on your bike?
I just installed the new mount from harley as well on my 06 flht and the vibration at idle is almost non-existant but from about 1500 to 2500 rpms, it vibrates like crazy. It's almost unrideable now at cruising speed. My whole dash vibrates to a point where I'm worried. I've heard that the new mount is made of a harder compound and you can install the Buell mount instead. I'm going to see if the dealer has one today and slap it on.
Old Jun 30, 2010 | 09:08 AM
Road King Kid
Why spend more money on another Rubber mount? I think that most everyone agrees urethane is the only way to go with replacement mounts. For just a few dollars more you can have a velva ride or a Glide Pro. Yachtman might even sell you his Velva ride for less than the cost of that Buell rubber mount.
Old Jun 30, 2010 | 02:02 PM
slack20's Avatar
slack20
shootfirst83 got the same thing goin on acts like the fairing is gonna jump off ROAD-KING never had swingarm off never looseened shaft 23,000 miles on bike yes a new condition shootfirst83, mine still shakes at idle pretty well also, have appt at dealer tom for neck bearing adj and fork oil change maybe i should have them look at alignment what does moco charge for alignment. help in ohio
Old Jun 30, 2010 | 02:24 PM
shootfirst83
Not sure what they charge. I went by today and ordered the buell mount. It only set me back 26 bucks compared to 45 for the harley one. I'll let yall know if it helps.
Old Jun 30, 2010 | 02:47 PM
slack20's Avatar
slack20
what was the part number for the buell mount had it here now cant find it.
Old Jun 30, 2010 | 02:52 PM
Road King Kid
Alignment will run 2 - 3 hours. Depends on if you have the exhaust removed or not. If you are mech. inclined, you can perform the alignment in your garage. All you need are a couple of lasers and a digital protracter. About $100 at sears.
Old Jun 30, 2010 | 10:00 PM
shootfirst83
Part number is L0501.2
Old Jul 12, 2010 | 09:30 AM
shootfirst83
So it turns out that the problem wasn't the mount but the mechanic...
I was looking at the motor and noticed it was touching the frame on the left side. After taking the voltage regulator off I noticed that when I replaced the mount I put the plate back on the wrong way. If you are having a lot of vibration I would suggest looking at where the plate is bolted to the motor. The two bolt holes that connect the plate to the motor should be bolted on underneath the motor, not on top.
Old Jul 12, 2010 | 09:56 AM
vickers1's Avatar
vickers1
well i just installed new hd front mount on my 2006-fltr still have terrible motor shake from 25mph-50mph any other suggestionS???,
Get rid of the H-D mount and get a Glide Pro. It works!
