Excessive Vibration - 2003 Bagger
Old Jun 23, 2010 | 07:50 PM
Road King Kid's Avatar
Road King Kid
Default Excessive Vibration - 2003 Bagger
My 2003 Road King has 27000 miles and I have been experiencing excessive vibration, both at idle and cruising down the expressway. I started off by replacing the rear rubber mounts with stock replacement parts from the dealer. The old ones were getting chewed up because I had reinstalled them improperly the last time I pulled the swing arm off.
After replacing the rear mounts, I noticed that the bike would no longer ride in a straight line with no hands on the bars. I used to be able to ride for miles without ever touching the bars, now I couldnt ride 100 yards without it changing lanes. Time to do an alignment.
After searching around this site and others, someone sent me a link to the Glide Pro website http://www.glide-pro.com/install/ which had an alignment process video. After multiple attempts, several trips to the store to buy/return lasers until I found the best one, and a couple of calls to Jake at Glide Pro, I finally got the bike to ride in a straight line. Unfortunately, I still have the vibration.
Jake told me about his Glide Pro system, and I have since read all about it. The thing is, I dont really have an issue with high speed wobble, just excessive vibration. I have not read much that would indicate spending $400 on the Glide Pro is going to solve my vibration issues.
I am thinking that the vibration problem might very well be due to my original front motor mount. I was thinking about just buying a Glide Pro front mount and see how this works.
Opinions?
Old Jun 23, 2010 | 08:41 PM
Bill03E's Avatar
Bill03E
front motor mounts go pretty easily , worth a shot...they will make the motor shake a lot if it is bad.
Old Jun 23, 2010 | 08:50 PM
shagnasty's Avatar
shagnasty
I'd try the front motor mount first. After 7 years the rubber has probably seen its better days.
Old Jun 23, 2010 | 08:52 PM
PnDegc's Avatar
PnDegc
This may be dumb idea - but did you check the fairing brackets?
Old Jun 23, 2010 | 09:18 PM
nastyHD's Avatar
nastyHD
Don't have an opinion on any of the Glide Pro stuff because I've never used anything from them but in the last 2 or 3 months I started to notice the same problem on my 05 road king with 34k miles, guess I'll swap the front mount too and see how it goes.... I probably won't get around to it for a couple weeks so please update us on how yours works out.
Old Jun 23, 2010 | 09:32 PM
Road King Kid
No, Roadkings do not have fairings.
Old Jun 23, 2010 | 11:02 PM
Yachtman's Avatar
Yachtman
Had a Velva Ride, eh. Now I have a Glide-Pro and it's very good. Worth the money.
Old Jun 24, 2010 | 05:53 AM
Road King Kid
I have not heard much about the Velva Ride. Did you replace it because it wore out or because it wasn't doing the trick? I see that the two are roughly the same price and both are made from urethane instead of rubber.
Old Jun 24, 2010 | 06:40 AM
Theakerr's Avatar
Theakerr
An extremely cheap suggestion is to replace your spark plugs (and possibly HT wires). It may be totally irrelevant but at the cost - so what. A while back, I posted an observation about general bike vibration and how i solved it by simply replacing the spark plugs. Several others made the same observation. It almost seems as though genuine HD spark plugs have a designed obsolescence.
Old Jun 24, 2010 | 06:59 AM
Road King Kid
This is an interesting concept. I just changed my plugs at the begining of the season and I do not use HD as they are rediculously overpriced. I now use Autolite which are only about $2.
That being said, I will get a new set today and see if I notice any difference.
